Have 73 f100 with 360 v8. Want an aluminium 4 barrel intake. Also need advise on Ford heads. Might make into a 390 ci. This is my first Ford project. Have owned truck since new.
Want to improve intake and exhaust with manifold,carb, and headers. Good used parts welcome.
Best single thing you can do without a lot of work is go to headers and dual exhaust. Then an aluminum intake and a 600-650 cfm 4bbl carb.
Leave the heads as-is for now with the exception of a good valve job.
If you want to go into the short block the two best things you can do is make it a 390 and get rid of the anemic compression ratio of the stock 360. This can all be done with stock parts.
As far as cam goes, that depends on how you are going to use your truck.
