Stay away from people who tell you to unplug the battery with the engine running. That's a good way to blow stuff up.
Get a good voltmeter, read the voltage on the battery with the engine off, and then read it with the engine running. You should have around 12v or so with it off, and 13.5-14.5v with the engine running.
it was a random event where the battery came unplugged, the bolt to the starter solenoid came off. it was a loose, attached it. just wandering why, the 88 next to it doesnt do this.
If you mean the positive cable came off the solenoid, no wonder it died. There is a couple other wires that attach there as well, and they power the charging system and the rest of the truck. No connection there, meant no power for anything else either........
Taking the cable off at the battery end (risky, as pointed out) should allow it to still run, since power from the alt is still getting to the rest of the electrical systems.
The battery is a significant "sink" for voltage spikes that could easily kill electronics. Basically it is a huge capacitor that steamrollers any spikes. And one source of spikes is the alternator - especially if it has a diode out. Let a few of those get through and you can easily lose the regulator or the ignition box.
But, I can't explain why another vehicle would run w/o the alternator. My experience is that all engines with alternators die instantly.
And the line between damper and capacitor is equally blurred - as I learned in "Parallel Systems". We used mechanical dampers to model electrical capacitors, restrictions to parallel resistors, inductors for springs, etc.
But, you are right, there is a difference. Which is why I said "basically". Figured people might know what a capacitor is - but an electrical damper?
Too true. Therefore, they have a harder time understanding what is going on with electrical systems, or even mechanical ones. A basic understanding of the building blocks makes all the difference.
