EBP Question
Old Sep 28, 2013 | 08:40 PM
RideDiesel88's Avatar
RideDiesel88
EBP Question
Im having a hard time programming it into my scan gauge..Ive tried it numerous times from the list on the scan gauge website but nothing comes up at all. Anyone have the right code to program? Much appreciated.
Old Sep 28, 2013 | 09:42 PM
jswartz84's Avatar
jswartz84
EBP hasn't worked on the 03s and 04s that I have tried it on.
Old Sep 28, 2013 | 10:19 PM
BLADE35's Avatar
BLADE35
PDF FOR 2003 6.0L EBP INFERRED STRATIGY FUNCTION
http://www.forddoctorsdts.com/techni...alOverview.pdf
Old Sep 28, 2013 | 10:21 PM
04badford's Avatar
04badford
EBP
TXD=07E0221445
RXF=046285140645
RXD=3010
MTH=001D0050ffb
this was my elevation# you have to find your Value PSI
my truck is late built 04
Old Sep 28, 2013 | 10:28 PM
RideDiesel88
Inferred stratigy function?? Whats that all about? the link isn't working
Old Sep 28, 2013 | 10:31 PM
RideDiesel88
Originally Posted by 04badford
EBP
TXD=07E0221445
RXF=046285140645
RXD=3010
MTH=001D0050ffb
That's the same code I entered. What do you mean elevation#? How do I find my value psi for exhaust back pressure?
Old Sep 28, 2013 | 10:35 PM
BLADE35's Avatar
BLADE35
IDK some links got changed recent this works
http://www.forddoctorsdts.com/downlo...alOverview.pdf
Old Sep 28, 2013 | 10:38 PM
04badford's Avatar
04badford
In your SG booklet xxxx will be the value of boost and shoot I have to read up on that one ,benny posted the link I'll try it
Old Sep 28, 2013 | 10:50 PM
RideDiesel88
So why did they even put the EBP sensors in the trucks? Does anyone know the code MAF to program into scan gauge? Apparently that's a critical one to compare with the others
Old Sep 29, 2013 | 07:35 AM
npccpartsman's Avatar
npccpartsman
The EBP sensor on the 03 trucks proved to be problematic so it was taken out of the PCM strategy and an inferred value is used. You won't be able to read it on an engine with the ICP sensor under the turbo. You can use MAP and BAR to compare to each other. I don't have MAF in my PID list for SGII.
Old Sep 29, 2013 | 07:44 AM
bismic's Avatar
bismic
<TABLE style="WIDTH: 541pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=721 x:str><COLGROUP><COL style="WIDTH: 541pt; mso-width-source: userset; mso-width-alt: 25628" width=721><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 541pt; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 width=721 align=left>Mass Air Flow (Gram/S)</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 align=left>TXD: 07E0221671</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 align=left>RXF: 046245160671</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 align=left>RXD: 3010</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 align=left>MTH: 000100010000</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 align=left>NAM: MAF</TD></TR></TBODY></TABLE>
Old Sep 29, 2013 | 07:48 AM
npccpartsman
Thank you Sir
Old Sep 29, 2013 | 08:21 AM
bismic's Avatar
bismic
I asssume it works, I haven't ever watched it on the Scangauge. Seems that every electronic gauge system has their own special quirks.
Old Sep 29, 2013 | 08:50 AM
npccpartsman
I'll key it in and see. I'm going to do a little turbo testing to see what my MAF is before I start changing turbo wheels. It's time for a change.
Old Sep 29, 2013 | 12:11 PM
04badford's Avatar
04badford
<table width="721" style="width: 541pt; border-collapse: collapse;" border="0" cellspacing="0" cellpadding="0" x:str=""><colgroup><col width="721" style="width: 541pt; mso-width-source: userset; mso-width-alt: 25628;"><tbody><tr height="18" style="height: 13.2pt;"><td width="721" height="18" align="left" class="xl24" style="border: rgb(212, 208, 200); width: 541pt; height: 13.2pt; background-color: transparent;">Mass Air Flow (Gram/S)</td></tr><tr height="18" style="height: 13.2pt;"><td height="18" align="left" class="xl24" style="border: rgb(212, 208, 200); height: 13.2pt; background-color: transparent;">TXD: 07E0221671</td></tr><tr height="18" style="height: 13.2pt;"><td height="18" align="left" class="xl24" style="border: rgb(212, 208, 200); height: 13.2pt; background-color: transparent;">RXF: 046245160671</td></tr><tr height="18" style="height: 13.2pt;"><td height="18" align="left" class="xl24" style="border: rgb(212, 208, 200); height: 13.2pt; background-color: transparent;">RXD: 3010</td></tr><tr height="18" style="height: 13.2pt;"><td height="18" align="left" class="xl24" style="border: rgb(212, 208, 200); height: 13.2pt; background-color: transparent;">MTH: 000100010000</td></tr><tr height="18" style="height: 13.2pt;"><td height="18" align="left" class="xl24" style="border: rgb(212, 208, 200); height: 13.2pt; background-color: transparent;">NAM: MAF</td></tr></tbody></table>
Thanks Mark I tore my books apart looking for that even went to SG site its not there .You da Man
