Opinions: GO!
Old Sep 27, 2013 | 11:48 AM
One Sick LX's Avatar
One Sick LX
Opinions: GO!
Just left a deposit on a 2004 Excursion Limited. Supposed to finish the deal Monday.
What do you guys think? Do you think I could have gotten him down more?
11975-
186k, new tires, leather, heated seats, no rust, runs strong, clean carfax (yea I know trust it as far as you can throw it), looks straight.......
This is the first one ive found locally. He was originally asking 13k.
link here: 2004 Used Ford Excursion Limited at Automotive Avenues Serving Wall,Toms River,Brick, NJ, IID 10959963
I'm not going to lie, i'm a little nervous. Ive wanted into the diesel game for a while now. Sold my 09 Silverado to get something cheaper but fun. And I don't have the bank at the moment to go toying with a 30k CPO diesel just to see if I like it.....
thanks for any input!!
Old Sep 27, 2013 | 12:20 PM
LivingLarge's Avatar
LivingLarge
Appearance wise, it looks great! Price is fair, actually for your market it seams to be on the low side. If all checks out mechanically, looks like a good deal.
Old Sep 27, 2013 | 12:23 PM
One Sick LX
Had a diesel mechanic look it over today... He gave me the thumbs up....
Old Sep 27, 2013 | 01:59 PM
ycis's Avatar
ycis
love the color, im pretty sure I read somewhere thats uber rare.
not sure how much more you could have gotten off of the price assuming all the mechanical stuff is sound!
take it for a test drive and beat on it, then check for any leaks thru the degass bottle cap.
Old Sep 27, 2013 | 02:36 PM
Apocalypse's Avatar
Apocalypse
Not to bad
Old Sep 27, 2013 | 02:41 PM
kornfanjoe's Avatar
kornfanjoe
I HIGHLY recommend getting something like a scangauge or any other obdII scan tool that can be used to tell you engine parameters like oil tmperature coolant temp etc etc.
with this you will want to get the truck up to full temperature and check the difference between oil and coolant temperatures. if its over 15 F then you have a plugged oil cooler and negotiate accordingly. if your ficm (fuel injection control module) voltage is less than 48 Volts during (+/- a volt or two) then the ficm is getting weak and will fail soon which can take injectors out. check this while starting the truck as well as when its running.
again make sure the coolant reservoir (degas bottle) doesnt have white residue or any signs of leaking as this can be a sign of headgasket issues.
there is lots to learn about the 6.0 especially over in the 6.0 specific forum 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums good luck and if you get it i hope you enjoy it! ive got nearly the exact same truck and i love it!
Old Sep 27, 2013 | 03:41 PM
VaSheriff's Avatar
VaSheriff
That's not Pueblo Gold as they advertise in the link. Pueblo Gold is a real light shade of gold.
It's Mineral Gray, and they are a dime a dozen, just as popular as black.
Old Sep 27, 2013 | 04:03 PM
mecdac's Avatar
mecdac
Looks like a pretty good deal for your area.
Old Sep 27, 2013 | 04:18 PM
ycis's Avatar
ycis
ah ok...guess my eyes arent as good as I thought they were.
lol
Old Sep 27, 2013 | 11:31 PM
Karlsgems's Avatar
Karlsgems
Sheriff,
Agree with you that is NOT pueblo gold. Mine is Pueblo Gold so I can vouch for what that looks like. Definitely Mineral Gray in the Ad.
Is mineral gray really common? I'm not sure it is. I see a lot of Exes (relatively speaking) here in SoCal and I hardly ever see mineral gray. I see more pueblo gold than mineral gray, frankly.
Anyone else know if this mineral gray was more common or less common?
To One Sick LX.....that Ex looks nice. Could be a real good truck for you. Good luck, and for what it's worth the price seems reasonable to me.
Karl
Old Sep 28, 2013 | 02:36 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I would be all over that thing! Where was something like that when I was looking?
anyhoo, get a Scangauge and drive it on the highway for 15-20 minutes at about 60 MPH. Check the Engine coolant temp (ECT) vs. the Engine Oil temp (EOT). should have a max difference of 15F. close to 15F or more difference and the motor needs a new oil cooler.
also, floor it several times and basically drive like a 16yr old trying to impress a girl. spin the tires a few times...get her nice and hot and up to temp. a little bit of turbo lag is normal from a stop. but even with those miles and "stock", the 6.0 should be able to easily spin the tires. pop the hood and look for "white" spray or evidence of previous spray on the hood liner, and at the degas bottle...this indicates lifting heads and bad headgaskets.
after you have it nice and hot, pull over real quick and turn the motor off. wait about 1 minute and start it. it should start back up easily. a failure to start, or prolonged start indicates a internal oil leak that will only get worse and leave you stranded.
lastly, with the Scangauge monitor FICM voltage. should never dip below 48 volts. if it does, the FICM is going out and those puppies ain't cheap. You can get them repaired for $200-500.
with the scangauge you'll have to visit the 6.0 section here on FTE for programming codes. the scangauge website has some of the X-codes, but FTE is the best source. It's a great tool (toy). Some of the best $159 I have ever spent. It works on any OBD-II vehicle.
that is a very nice looking rig. I'm jealous of your find. Best of luck with it. I had a 6.0 and loved driving it. Great power, good MPG's, and the 5R110 trans is amazing
Old Sep 28, 2013 | 02:46 AM
Skip1970's Avatar
Skip1970
thats like a witch hand holding that lighter!
Old Sep 28, 2013 | 06:15 AM
mecdac's Avatar
mecdac
Witch hand
Come here you little pretty...
Old Sep 28, 2013 | 09:00 AM
VaSheriff's Avatar
VaSheriff
Originally Posted by Karlsgems
Sheriff,
Karl
It is on the east coast. But this could be because the rental agencies all purchased Mineral Gray and then sold them later as used vehicles. 98% of the Excursions I see in a 100 mile radius around me are Black or Mineral Gray. Pueblo Gold is rare where I live, I don't recall ever seeing but maybe one in my travels for the last 10 years. Occasionally a spruce green or toreador red will pass before my eyes! White, only saw those back in the early model years as Eddie Bauer models. The dark green, wow, those are extremely rare too?? I have never seen one around here where I live.
Old Sep 28, 2013 | 10:54 AM
az_r2d1's Avatar
az_r2d1
Get ready for frequent wrenching.
Oh, better start saving up for repairs too.
HIGHLY recommend the scangauge and check for ALL signs of trouble BEFORE buying.
The salesman will put pressure on you... don't. First check it all
