1978 - 1996 Big Bronco
rear brakes keep siezing?
Old Sep 18, 2008 | 08:38 AM
wynntown marshal's Avatar
wynntown marshal
Hey Y'all,
ive a 91 bronco. Replaced the rear brakes 3 times in the last two months. Initially thought I'd set them up wrong then gave it to a garage for the last re-fit.
Replaced, shoes, hardware, flexi, wheel cylinders, brake pipes and master cylinder.
and its still does. Rear Anti lock light comes on most of the time also. Mechanic said he couldn't see any sign of abs fitted to the rears?
Anyclues greatly appreciated.
Keith J in bonny scotchland
Old Sep 18, 2008 | 09:17 AM
wynntown marshal
cancel that. just found some other answers to this elsewhere on the site. bin the abs valve seems to be the general conscensus!
Old Sep 18, 2008 | 12:17 PM
Kemicalburns's Avatar
Kemicalburns
you will also have a rear abs sensor on top of the rear diff. pull this out and clean it up good. if its not hooked up this could also be part of your problem
Old Sep 18, 2008 | 01:02 PM
andym's Avatar
andym
If your mechanic couldn't figure out that your truck has rear ABS, then you need a new mechanic.
And yes, it's the ABS valve. Bypass it with a piece of brake line for best results.
