351m 460 swap
Old Sep 26, 2013 | 07:17 AM
willfordgq's Avatar
willfordgq
351m 460 swap
I recently changed the motor in my 77f150 to 460. The 351 ran still but I got a deal on the 460 it ran very well so I swapped them out also I used the 351 ignition system for the 460 did not change anything to wiring or interal parts but I can not get this engine to fire up for nothing rebuilt the carb it gets fire from the coil ect I am just stuck at this point any suggestion?
Old Sep 26, 2013 | 07:32 AM
jim collins's Avatar
jim collins
Was the ignition ,coil , dist. working right with the 351m ? If so all i can think of is that a connection is not being made someplace , maybe a loose or broken wire. Check the rotor to make sure it's not cracked or broken , cap too . Change out the coil to dist. wire , may be broken. That's all i can think of this early in the morning , just on my first cup of coffee.
Old Sep 26, 2013 | 08:08 AM
willfordgq's Avatar
willfordgq
If you pull it off and turn over the motor it fires when holding it with a small gap to the coil. I am gonna put new plugs in it and try that. I am really needing the beast to run soon.
Old Sep 26, 2013 | 09:16 AM
Jdeshler's Avatar
Jdeshler
Haha, I'm on my first red bull Jim..(need to quit em).. anyways, Wilford, check you're connections at the duraspark box (grey box on the drivers fenderwell) very well and the connections into the distributor.. you're just missing a loose plug somewhere.. I'm upgrading to a hei style distributor soon In hopes of chasing off all my ignition uncertainties.. just walk away for a minute then the problem will be right there when you go back. . Good luck!
Old Sep 26, 2013 | 09:22 AM
Jdeshler's Avatar
Jdeshler
Is it firing lightning or a little spark? It should be cracking and shocking the crap out of you if you're holding it..
Old Sep 26, 2013 | 09:36 AM
wotan's Avatar
wotan
Any chance the dizzy is 180 degrees off? Or a tooth or two off?
Old Sep 26, 2013 | 12:49 PM
jim collins
Yeah you guys get the sun shine about the time i get up, 4:00 AM. here . Wish i could drink a Red Bull but can't do it any more . Old age mess's up a lot of thinks , have fun when you are young, L.O.L.
Old Sep 29, 2013 | 07:05 PM
willfordgq's Avatar
willfordgq
It almost fired up and then just turns over. I am 100% sure it is in time and I have checked everything ten times over. My grandpa suggested put the points type distributer back in and try it that way. It is something simple but just can't find it.
Old Sep 29, 2013 | 08:19 PM
Jdeshler's Avatar
Jdeshler
I 100% agree with that.. I had so much trouble with the factory duraspark box I thought about burning my truck once or twice points if regulated right are very reliable
Old Oct 4, 2013 | 04:08 PM
willfordgq's Avatar
willfordgq
It has alittle spark what would that be?
Old Oct 4, 2013 | 04:10 PM
willfordgq's Avatar
willfordgq
I am gonna try putting the points type distributer in it and see what happens this weekend hopefully maybe it will work.
Old Oct 4, 2013 | 05:30 PM
Jdeshler's Avatar
Jdeshler
I'm sure if you're patient with the system that's in it you can get it rolling right but when they start getting troublesome I take that as an opportunity to put a HEI style or points ignition.. after that its smooth sailing
the glassman
Jul 19, 2006 11:58 AM
john460
Electrical Systems/Wiring
Apr 28, 2004 06:48 PM
AMiller320
Oct 23, 2002 12:49 PM
dzjammer
Jan 14, 2001 02:36 PM
