'02 X Data Link Connector missing a wire
Old Sep 24, 2013 | 08:22 PM
Ddeang2's Avatar
Ddeang2
My '02 X started running rough and stalling which triggered check engine light. I couldn't get a connection to the DLC to read codes, but did find that the white wire in the harness was not connected to the DLC. There is tape on the wire so this may have been a temporary fix by the previous owner. There doesn't seem to be a plug in the connector missing a wire so there is no way of telling which hole the white wire belongs in. Haynes repair manual doesn't have any wiring diagrams that show the DLC, although I may have missed it.
Without a photo or diagram I'm lost as to how to determine where the white wire goes. Need to fix this before I can pull codes.
Old Sep 24, 2013 | 08:25 PM
Stewart_H's Avatar
Stewart_H
Check your cigarette lighter fuse. If it's burned out, replace it. That same fuse powers the OBD II port.
Stewart
Old Sep 24, 2013 | 08:31 PM
sammie0126's Avatar
sammie0126
Have you checked the fuse? That white wire may have nothing to do with your DLC. I think I have a diagram that came with my scanner that shows which pins are used for your vehicle, but I would have to dig that out tomorrow.
Old Sep 24, 2013 | 08:34 PM
Ddeang2's Avatar
Ddeang2
DLC
It just so happens that the cigarette lighter doesn't work. Let me start there.
Old Sep 25, 2013 | 06:36 PM
Ddeang2's Avatar
Ddeang2
DLC needed new fuse
DLC powered up w/new 20 amp fuse. Got P0720 - insufficient input from Output Shaft Speed Sensor. Is there I thread that has already discussed this?
Old Sep 25, 2013 | 08:42 PM
Stewart_H's Avatar
Stewart_H
Which engine do you have?
Stewart
boone13
Aug 21, 2018 09:47 PM
1974f250390
Jul 17, 2017 04:23 PM
bankert8806
16
May 8, 2013 11:50 PM
Jeep Guy
Feb 18, 2006 06:14 PM
fordmudrunner2020
Feb 27, 2004 08:35 AM
