Header exhaust leak
Have to watch how you tighten those ball sockets. If the pipe is not lined up correctly, it will pinch/distort the ball and cause a leak. Especially if the pipe socket side is not large enough to fit over the ball side. Been there, done that. I had to drop the front pipes and using a small cresent wrench work the radius back into the header side "ball". Then easily snug the pipe back up.
I bought shorties like that, then a dual kit that was suppose to fit stock manifolds. Don't know which part is faulty, but nothing liked up correctly til I cut/welded/bent things around.
I know the old gasket ring was a PITA when they blew out, but this new stuff doesn't always fit correctly.
tealboy1
12-29-2008 09:35 AM
