p0500
Old Sep 23, 2013 | 08:47 PM
KRDiesel's Avatar
KRDiesel
p0500
Replaced the vss in the rear end with a motorcraft part from the dealer, Still have the code, no speedo, and the ABS light is on. I also have a fan controller code, should I look for a fuse, wiring issue, or what??
Where is the other end of the wiring? Straight into the PCM?
Old Sep 23, 2013 | 09:05 PM
m-chan68's Avatar
m-chan68
Do you have power and ground to the ABS module? Do you have a scan tool (or access to one) that can read the wheel speeds of all three speed sensors (RF, LF and rear)? If so, it would be wise to try and monitor them. If you have verified GOOD power and ground to the ABS module (on some vehicles there are TWO powers and TWO grounds), load test and check for continuity between all six wires for all three sensors between the main ABS module and the sensor connectors directly. You don't need a wiring diagram. Just match the colours of the wires at the main ABS module connector and the speed sensor connectors. I suspect I should have you covered pretty good with all the info listed above.
Old Sep 23, 2013 | 09:20 PM
KRDiesel's Avatar
KRDiesel
Thanks!!
I found it. Fuse 25 was blown. That is the ABS module and the engine fan fuse.
Replaced fuse and everything is happy!!
Old Sep 23, 2013 | 09:21 PM
KRDiesel's Avatar
KRDiesel
tried to rep you, but I must spread the loving around before it will let me
Old Sep 23, 2013 | 09:26 PM
m-chan68's Avatar
m-chan68
Originally Posted by KRDiesel
Thanks!!
Whenever checking ANYTHING electrical, always remember it needs power and ground to function. Your blown fuse meant your power side was missing.
remotevirus
Dec 14, 2021 11:21 PM
FTreeFidd
May 19, 2018 04:48 AM
george14094
Jan 17, 2013 07:25 PM
catfish4
1997 - 2003 F150
Aug 22, 2011 12:20 PM
malbojah
3.8 & 4.2L V6
May 25, 2006 01:45 PM
