Oil pressure ?
Old Sep 22, 2013 | 09:37 AM
karjunkie's Avatar
karjunkie
Oil pressure ?
Hi fellas i am having oil pressure issues (or the lack thereof) on my freshly rebuilt 390, tried the old pump vs new pump same pressure which is 20psi cold and drops within the minute or so to 10psi and that's with a real high idle, even at 1500-2000 rpm the pressure will not go over 20 psi and if i throttle it up it wont go over 20 psi, and i am using gaskets for the pump and sump tube, even took the dizzy out to try to prime, still the same results the only ting i can think of is if he didn't plug one of the oil gallery's
Old Sep 22, 2013 | 10:40 AM
MIKES 68 F100's Avatar
MIKES 68 F100
sounds like a galley plug got left out , there's a bunch of them under intake , most common to miss is the one by dizzy it's recessed .
Old Sep 22, 2013 | 11:08 AM
orich's Avatar
orich
Was this changed over to adjustable rocker arms was? What oil wt. you using?..orich
Old Sep 22, 2013 | 06:37 PM
karjunkie's Avatar
karjunkie
non adjustable rockers, and im usin 15 /40
Old Sep 22, 2013 | 06:40 PM
karjunkie's Avatar
karjunkie
i know the ones under the intake are there, but the other by the dizzy, how far recessed is that one, and is it right inline with the lifter gallery .
Old Sep 22, 2013 | 06:52 PM
MIKES 68 F100
if you pulled dizzy it's actual in that hole facing lifters
Old Sep 22, 2013 | 06:58 PM
MIKES 68 F100
I love the internet . it's the red arrow
Survival Motorsports Fe Engine Factory Pressin Oil Galley Plugs Photo 3
Old Sep 22, 2013 | 06:59 PM
karjunkie's Avatar
karjunkie
Mike so if i prime my oil with a drill motor should i see oil pouring out by the dizzy drive gear area
Old Sep 22, 2013 | 07:01 PM
karjunkie's Avatar
karjunkie
ahh i get the picture now, haha, the link for the pic showed up after my last post
Old Sep 22, 2013 | 07:25 PM
karjunkie's Avatar
karjunkie
well i checked the gallery and there is oil coming out the gallery, at least i found a problem
Old Sep 22, 2013 | 07:41 PM
MIKES 68 F100
problem found good
Old Sep 22, 2013 | 07:43 PM
karjunkie's Avatar
karjunkie
Mike, can oil pressure be that low because of one gallery plug
Old Sep 22, 2013 | 08:02 PM
MIKES 68 F100
yup ! turn on your kitchen sink , now turn on your shower and kitchen sink . open galley will cut your pressure big time .
Old Sep 22, 2013 | 08:42 PM
karjunkie's Avatar
karjunkie
ya that's very true, well got that gallery blocked still very low oil pressure , thinkin the gallery by the timing chain might be open too, i will look into that tomorrow, gettin a lil late need ta relax b4 gettin some rest for the night
karjunkie
16
Sep 29, 2013 05:15 PM
austinlittle34
May 21, 2013 12:51 AM
kweiss
Mar 28, 2012 06:16 AM
thefireman4652
Aug 4, 2003 11:09 AM
Adrienc9
Jun 13, 2003 04:47 AM
