Oil pressure
Old May 20, 2013 | 11:15 AM
austinlittle34's Avatar
austinlittle34
Oil pressure
How much psi of oil pressure should a 1990 4.9 have
Old May 20, 2013 | 11:42 AM
blue924.9's Avatar
blue924.9
how much do you have
Old May 20, 2013 | 03:19 PM
austinlittle34
Only 40 @ 2000 rpm and I'm cammed over high performance lifters so I'm a little worried
Old May 20, 2013 | 04:12 PM
blue924.9's Avatar
blue924.9
that sounds allright, how much do you have on idle, if you are worried install a higher flow, not a higher pressure pump, with higher flow comes higher pressure the pumps advertised as higher pressure usually just use a more restrictive oil path
Old May 20, 2013 | 04:40 PM
austinlittle34
25 psi @ 600 rpm
Old May 20, 2013 | 08:13 PM
MeanGreen460's Avatar
MeanGreen460
What weight oil are you running? How many miles on your engine?
Old May 20, 2013 | 09:46 PM
austinlittle34
10w30 and 74,000 I just rebuilt it from the Cam up all new valve train and head there's only 75 miles on the rebuild
Old May 21, 2013 | 12:51 AM
TexasGuy001's Avatar
TexasGuy001
Those numbers sound fine to me. I don't see any reason you'd need any more than that. If you did have much more pressure, it would most likely cause oil leaks.
cornking
Dec 12, 2007 12:37 PM
menzfamfour
Jul 7, 2007 03:33 AM
rmalottwtes30
Jan 7, 2006 06:41 PM
Chris
1978 - 1996 Big Bronco
Aug 21, 2001 08:30 AM
