TURN IT,REPLACE IT, OR LEAVE IT.
Old Sep 21, 2013 | 02:26 PM
gradyc's Avatar
gradyc
wellhead
01 F250 2WD-105XXX.
Noticed a slight pull to the left when applying the brakes.
Pulled left front down to the rotor. Slide pin are good. The pads need replacing. The back side of the rotor has two small groves approx. 1/16" deep.
What do you guys suggest. Will the grooves compromise the braking on that wheel.
I will be replacing all the pads and checking the rotors.
Thanks in advance.
Old Sep 21, 2013 | 03:01 PM
Jklnhyd's Avatar
Jklnhyd
When you take it in to turn it, they will tell you if it can be turned or not. I would at least turn them both to the same thickness. And fix the problem that caused the grooves.
Old Sep 21, 2013 | 03:08 PM
AllaboutMPG's Avatar
AllaboutMPG
Grady
here's a recent thread about brakes with some discussion about turning vs not turning. Appearently what applied years ago does not apply today. Turning may not be a good idea. If it was me I would just replace all the pads on both sides and leave it alone as long as it's not warped. https://www.ford-trucks.com/forums/1...es-please.html
Hope this helps
Old Sep 21, 2013 | 07:35 PM
dn29626's Avatar
dn29626
Originally Posted by AllaboutMPG
...I would just replace all the pads on both sides and leave it alone as long as it's not warped...
....X2....
Old Sep 21, 2013 | 09:31 PM
gradyc's Avatar
gradyc
wellhead
Will only be putting on OEM pads.
Thanks for the advise everyone.
Old Sep 21, 2013 | 09:55 PM
jeffreyt's Avatar
jeffreyt
I wouldn't turn them simply because last time I had some turned, it was only $20 or so cheaper than replacing them, but that was them pulling them (how hard is it to take off a tire?) I've replaced them on both trucks All the way around and would again if need be.
Old Sep 22, 2013 | 08:24 AM
kawcrasher's Avatar
kawcrasher
Originally Posted by gradyc
01 F250 2WD-105XXX.
Thanks in advance.
Leave it or replace it, turning isn't worth it anymore. I'd probaly run it as is.
Your pull to the left is most likley something frozen up on the right side. Along with the slide pins make sure both pistons move free in the bores. I have way more problems with the pistons sticking then the slide pins.
Old Sep 22, 2013 | 11:22 PM
gradyc's Avatar
gradyc
wellhead
Slide pins moved freely in their bores. What is the best way to check the pistons movement in their bores? Place a board as a stop so the pistons will stay in their bore.
Finished sanding and cleaning the discs surfaces prior to going back with the oem pads.
Old Sep 23, 2013 | 06:14 AM
danskool's Avatar
danskool
Go Bills !
Originally Posted by dn29626
....X2....
x3
I would change both front pads and operate pistions with pads off and a c-clamp to make sure pistions move freely. Make sure pins are free.
If still pulling i would head to the back and do the same on the back.
Old Sep 23, 2013 | 10:15 AM
USMCJosh's Avatar
USMCJosh
If it pulls to the left your right side is suspect. Make sure you have the right rotors. Ford has so many different types of rotors (early 99 and late 99 for example) that it's easy for the parts guy to give you the wrong one and it still mostly fit. I have an early model 99 for example. The guy @ the parts shack gave me late 99 rotors. I put them on and the wheel physically wouldn't move. The reason I was replacing the rotors was that there was the groove on the back where they had rubbed off on the steering knuckle. The late 99 rotors have about a 1/8" deeper hat on them which will cause what you are talking about if put on early 99 model trucks. You might have the same sort of issue.
Old Sep 23, 2013 | 09:18 PM
gradyc's Avatar
gradyc
wellhead
Guys, Thanks for your input. Pads are on and all is back together. Didn't have time to test drive it today.
Soccer85
Dec 27, 2015 01:22 PM
bandlgeorge
13
Apr 20, 2010 09:33 AM
Scurvydog
Aug 20, 2006 08:34 PM
96expblk
Apr 24, 2006 08:12 PM
fordtrucklover94
1983 - 2012 Ranger & B-Series
Apr 28, 2005 12:57 PM
