52 rat rod frame swap info
Curious as to why this truck was available without the frame? Could if be the previous owner decided that it was too big of project without a frame.
For anybody that is interested the 83 to 97 Ranger long bed has a wheel base of , 113.9".
The 48 t0 52 f-1 has a wheelbase of , 114"
I put a 51 f-1 on one of the 83 frames , it fit okay but not what i was after.
They drop a lot in the center under the cab , which would be okay for a rat rod . But then you loose a lot of the box area when you lower the cab down ,again okay for a rat rod.
I later mounted the cab on a 92 4x4 super cab ranger frame . It was better but the frame needed cut or a flatbed put on . I ended up selling it along with a couple of other projects due to having to relocate where i live.
Here are the measurements for the original frame to give you a idea. I have helped friends with frame swaps before. Mock up several times before you cut anything. Any pictures of the condition of the cab. Is the original floor intact? If you get a frame that isn't off by much you can spread that out between the gap between the cab and bed, and slightly off center the wheel wells. You could hide a couple of inches that way.
If you floor is intact look up a some pictures of how the cab is originally mounted and try to duplicate that type of mount. If you use only the (S-10 for example) frame mounts the floor in that location would have to be braced up and may not look right. It usually works out better cutting those mounts off the frame and trying to duplicate the original style mounts.
