Status Update
Rebuilt injection pump; new throttle position sensor; new fuel return lines, t's and o-rings; new glow plugs; new tensioner, idler pulley and serpentine belt; new fuel pump; new batteries, new windshield wiper motor; new hood hinges; new hood latch; new master brake cylinder, brake booster and brake lines; new ball joints; new brake calipers; new inner and outer front wheel bearings; new rotors; new front brake pads, new front shocks.
New drive shaft u-joints; new carrier bearing.
New rear brakes, drums, and cylinders; new rear axle bearings (one new hub bolt, rascal broke); new rear shocks, new front fuel tank with extremely expensive new sending unit (rear tank awaiting an inexpensive sending unit before
installation); 2.5" to 4" exhaust from the mainfolds back (Rock Auto).
Oh yeah...changed the oil (Rotella 15W-30), fuel filter (wix), and coolant (fleet charge).
OK, I think that's all...my pockets hurt, my head hurts, and my back hurts. I am only making this information public in case someone has the same issues as me and has to find parts in expensively, I can give them some help. The truck rides good, sounds good, and has fairly good fuel mileage (around 15mpg if I don't act like it's a car). Thanks for taking the time and a special thanks to Vic Felix!!!
I do have a question: where can I find cab corners and door rails for the 1993 Ford F-350, time for body work?
Doc
Old Fuel Sending Unit
http://s5.postimg.org/dwz5yzuhj/IMG_0067.jpg
New Carrier Bearing
http://s5.postimg.org/62ykdlmon/IMG_0068.jpg
Spindle Before I put everything back on
http://s5.postimg.org/65ig0fqc7/IMG_0072.jpg
4" tailpipe sticking out the back
http://s5.postimg.org/4ezeyy8t3/IMG_0110.jpg
New Exhaust
http://s5.postimg.org/xvf11df6f/IMG_0111.jpg
