How to activate 4WD
Old Jun 17, 2003 | 09:34 PM
dgardner's Avatar
dgardner
How to activate 4WD
Hi everyone. I'm new to 4WD. I Owned all rear wheel drive cars ( all Fords). I just got a 2002 4WD Explorer. One question about putting it in 4WD. Do you have to be stopped before you use 4WD Auto / 4WD High / 4WD Low? My dad said that 92 Ranger you had to stop put the truck in neutral and activate 4WD Low. Thanks for your help.
Old Jun 17, 2003 | 09:56 PM
stubborn1's Avatar
stubborn1
How to activate 4WD
You don't have to be stopped to put it in 4wd hi. Just turn the switch and away you go. Be careful not to use 4wd on dry pavement because you can cause damage to the system components. Only activate it on gravel roads (or other loose surface), snow, or when heavily raining.
I think you have to be stopped to use 4wd lo. If I remember right, you turn the switch to 4 lo, put the vehicle in neutral, wait for the light on the dash to indicate 4 lo (you can hear the transfer case shift also) and put back in drive.
I would strongly suggest reading the owners manual section on 4wd if you are unfamiliar with it. I also think I have instructions under the drivers side window visor. Read these, it will save you some headaches.
Old Jun 17, 2003 | 10:49 PM
dgardner's Avatar
dgardner
How to activate 4WD
Thanks stubborn1. I did read the manual but it didn't say anything about putting the truck into neutral or anything. It just talked about the types of conditions to use the 4WD(which was basically common sense). I will check under my visor tomorrow. Thanks for the info
Old Jun 18, 2003 | 11:31 AM
SplashMan's Avatar
SplashMan
How to activate 4WD
stubborn1 is correct... 4HI just turn the switch at any speed up to 55, 4LW stop, neutral, turn switch and wait for the light.
Old Jun 18, 2003 | 02:47 PM
1956MarkII's Avatar
1956MarkII
How to activate 4WD
There's one more step to getting into 4low: you have to be in 4hi first. You can't just switch from 2hi (or 4auto, whichever one you have) to 4lo. So, switch in to 4hi, come to a complete stop, put tranny in neutral, switch to 4lo, wait for the light, then put it in gear. Reverse the procedure to get out of 4lo. By the way, there is a fail-safe feature built in. If a passenger reaches over to operate something else and accidentally swithces you into 4lo while the vehicle is moving, nothing wil happen. just switch it back to where you had it. Can you imagine what would happen if you could shift into 4lo at 70mph? OUCH!!
Old Jun 18, 2003 | 02:56 PM
dwessels's Avatar
dwessels
How to activate 4WD
One more step to that, your foot must be on the break for 4-low to engage. Also, my owner manual for my '96 says you can run in 4-Hi all year long if you want to, but you get worse gas mileage. I wouldn't recommend that.
Old Jun 18, 2003 | 08:49 PM
dgardner's Avatar
dgardner
How to activate 4WD
Thanks Everyone. One last question. What is 4WD Auto? That is my 3rd 4WD button.
Old Jun 18, 2003 | 10:05 PM
SplashMan's Avatar
SplashMan
How to activate 4WD
If your X senses loss of traction it will automatically switch it into 4wd.
