Sponsored by: Real Truck
Speaker Recommendations
Old Jun 17, 2003 | 08:44 PM
PeteC's Avatar
PeteC
I want to upgrade the speakers in my 99 F350 Crewcab. I bought some Pioneer 3-way speakers at Walmart. What a big mistake. The Pioneer's sounded worse than the factory speakers.
I don't need super-duper $200+ speakers, just some nice ones that are an improvement over the factory ones, preferrably under $100.
Thanks,
Pete
Old Jun 17, 2003 | 09:24 PM
smcdonn's Avatar
smcdonn
The most amazing speaker I have ever heard was a set of Infinity 2 ways in a truck. It was outright nivana to the ear's if your looking for outright sound quality. The price may not be in your range though. I don't have any prices off hand. sorry
Old Jun 17, 2003 | 10:00 PM
OGNOM's Avatar
OGNOM
Checkout JL Audio............sweet
Old Jun 18, 2003 | 12:59 AM
SouthernDually's Avatar
SouthernDually
Thumbs up Speaker Recommendations
I went the way of Infinity in the rear and the Alpine in both doors. I liked the infinity because of the outstand clairty and the alpine because of the volume.. As far as base I went with the sureform and 2 10's under the rear seat. Everything is driven with an Alpine 342. Great for making the young ones look around and try to figure where the sound is coming from..
Old Jun 18, 2003 | 06:17 AM
Yeti's Avatar
Yeti
Like these guys, I run Infinity components in the front and Infinty mids in the back and a couple 10" JL subs.
Old Jun 18, 2003 | 07:59 AM
oppy's Avatar
oppy
I agree - get the Infinity Kappa 5x7s. They'll fit right in the stock openings and they sound great. Check eBay, they're available constantly for $75 or so a pair.
Old Jun 18, 2003 | 10:32 AM
drscotch's Avatar
drscotch
Here's another vote for the JL Audio's. I have fronts with remote tweeters and coaxials in the back. Awesome sound.
Old Jun 18, 2003 | 11:14 AM
nickdoni's Avatar
nickdoni
Did you guys install amps too,or just new speakers?
Old Jun 18, 2003 | 11:29 AM
V10KLZZ71S's Avatar
V10KLZZ71S
I have Boston Acoustics 6X8's bolt right up.Sony X-plod 4 channel amp driving front and rear speakers.Bazooka self powered bass tube.Its a pretty decent setup.
Old Jun 18, 2003 | 11:32 AM
drscotch's Avatar
drscotch
I have an Alpine high power MP3 deck which drives the 4 speakers and an MTX 250 watt amplifier under the passenger seat to run the sub. Nice setup.
Old Jun 18, 2003 | 01:08 PM
oppy's Avatar
oppy
I think it really depends on you and your tastes. The upgrade speakers will sound a lot better than the crappy stock ones - maybe you'll be happy with that. If not, the sky's the limit
If you want to get more sophisticated, check out the audio forum - there's a whole bunch of experts with great ideas there.
Old Jun 18, 2003 | 04:04 PM
PeteC's Avatar
PeteC
I just want to upgrade the speakers. I don't need amps or separate woofers or anything fancy.
Old Jun 18, 2003 | 05:05 PM
Fords For Ever's Avatar
Fords For Ever
PeteC, I agree with what Oppy wrote because I installed four Infinity Kappa 572.5's which I bought off E-Bay for about $75 a pair. I did a fair amout of research and was worried the factory HU would not power the speakers well enough. They did sound much better than stock with the factory HU but I already bought high output Alpine HU so I put that in. If I had not already bought the Alpine I might have stayed with the factory HU because I like the stock look better but the Kappas do sound better with more power. I don't think you will be disapointed though. My 2 cents. Good luck.
Old Jun 18, 2003 | 11:57 PM
Tim Ervin's Avatar
Tim Ervin
When buying speakers look at the nominal rating not max as advertised. Most 100-200W speakers will run fine on a good factory or aftermarket tuner/player. I have Pioneers in mine. Front, rear and system. The key to Pioneer components is to get the better ones. They're like Sears used to be. They have something for everyone but I don't like the cheaper ones or the higher end either. I ain't knocking any brand but I can put together a $350-400 system that makes $1200 owners envious. The key is matching everything to compliment each other. Crutchfield helps alot too. Even if I don't buy from them, I can compare specs. on speakers, receivers etc. I have great respect for Alpine, better Blaupunkts, and Clarion. I don't have much experience with cars or "roomy" trucks though so the INfinity's may be in order to get enough volume. Another note, most of WalMart car audio equipment (and Mom works at WalMart) is bought in batches or bids. Pioneers numbers are generally different at Sears (e.g. 693 is a lower quality than a 4 digit). WalMart also keeps older versions longer. The factory setup should run the speakers unless you need really high volume or add alot of bass. I'm deaf but I also drive a regular cab. guess I've rambled enough.
Old Jun 20, 2003 | 11:46 AM
Tman634's Avatar
Tman634
I put a set of the Pioneer 3 ways into the doors and a set of Pioneer 2 ways into the rear. What model did you get from Wally world? Mine were purchased thru Crutchfield and rock!! I also install a Kenwood 4x100w amp to power them. The stock deck can't quite push what they need to work well. I also have a Fosgate 200w punch amp powering a 10" tube between the seats. All the filler you need.
