PIP Help
Old Sep 18, 2013 | 07:59 PM
AjRanger88's Avatar
AjRanger88
PIP Help
Ok guys just a quick question, I did the AC test on the PIP sensor on my 89 ford f-150 that has a missing issue, I am getting a reading of 8.7 to 10.2 . this is higher then the book. should I go ahead and change it?
Old Sep 18, 2013 | 08:45 PM
subford's Avatar
subford
If the PIP sensor missing one out put it will set a code in the Computer memory. What codes do you have in computer memory?
I am not sure what book you are talking about that says something about voltages. I also do not know what wire you were on when you took the readings.
Old Sep 18, 2013 | 09:23 PM
AjRanger88's Avatar
AjRanger88
Pip wire to ground to check AC voltage. Haynes manual. I don't understand how to read the codes I keep trying and I know it has one but I can't figure out the code when counting needle swipes on my analog meter. Don't know how to explain but I just can't figure the code out.
Old Sep 18, 2013 | 09:33 PM
Conanski's Avatar
Conanski
Take video of the codes with your phone and post it up.
Old Sep 18, 2013 | 10:44 PM
AjRanger88's Avatar
AjRanger88
I'll do it tomorrow
Old Sep 19, 2013 | 06:11 PM
AjRanger88's Avatar
AjRanger88
Where can I upload my video, I took two. one of codes, and one of truck running for audio purposes. I don't have a youtube account or anything. I can just e-mail them to someone who can help
Old Sep 19, 2013 | 06:21 PM
AjRanger88's Avatar
AjRanger88
I feel like i'm getting plenty of fire, but at the wrong time. pulled the number 8 wire with truck running and it doesn't effect how the truck idles at all, but it is firing. I did the basic stretch test on the timing chain today and only had 2 degrees of rotation before the distributor started to move. so all good there. is it possible that the timing chain has jumped a tooth?
90fordf-250
Jan 2, 2012 10:34 PM
c3racer2000
1978 - 1996 Big Bronco
Nov 28, 2011 03:59 PM
LoosMaster
Apr 8, 2006 06:16 AM
skidj0003
Jun 20, 2003 10:37 PM
mayerst
Jun 18, 2002 02:23 PM
