1978 - 1996 Big Bronco
Front seat
Old Jun 17, 2003 | 08:25 PM
rcarter's Avatar
rcarter
Front seat
I have a 1996 bronco xl with the cloth bench seat.
The driver side back rest leans back farther than it should.
I have looked to see what was bent but have not been able to find a way to correct it.
I have tried bending the the stop on the seat back and this helps some but does not correct the poblem completely.
Any one had the same problem?
RAY
Old Jun 18, 2003 | 06:29 PM
rcarter's Avatar
rcarter
Front seat
Has know one had this problem????
Ray
Old Jun 18, 2003 | 10:27 PM
justshootme84's Avatar
justshootme84
Front seat
Check the floor mounts on the inner side, next to the console. They tend to break and will cause problems with the driver's seat!
Old Jun 19, 2003 | 11:54 AM
TheBlackRhombus's Avatar
TheBlackRhombus
Front seat
Check any of the mounts on the floor - If they rust out, bend or break, the seat is gonna lean no matter what you do. They're a cinch to fix......
Old Jun 19, 2003 | 03:15 PM
fcarruth's Avatar
fcarruth
Front seat
I took my 89 into FORD a couple of years ago and there was a TSB on the seat rail and a problem with the mount. They did the repair fror free. You could probably call your local dealer and give them your VIN and they could run it and see if there was anything that needs to be done.
Old Jun 19, 2003 | 03:28 PM
Turnerscasa's Avatar
Turnerscasa
Front seat
Yea on my 89 Bronco the driver seat leaned like that. It turned out the floor pan where the seat rails bolt to the floor was ripped. I had to have some strength built (welded) in that area. I don’t know if mine is different from yours but the floor pan steel is not very thick there. I think the guy that owned it before me was a really big dude, and that won’t help ya either!!!
Old Jun 19, 2003 | 08:32 PM
rcarter's Avatar
rcarter
Front seat
Thanks
I did not think of checking the floor. As soon as this rain let up and the ground drys I will get under it see whats up.
ray
Old Jun 20, 2003 | 11:31 PM
justshootme84
Front seat
I forgot all about the floor pan! Mine was cracked about 5-6" under the rear-outside mount for the driver's seat, as well as both inner mounts and both seat crossmembers being broken. I think what happens is that when the seat mounting tabs break, then the floorpan cracks. (The previous owner was 300+#) After welding the seat tabs and crossmembers (using a wet cloth to keep from burning up the seat foam), I hammered the cracked floor back into position and welded it. I also made a bracket to bolt under the floor, as well as one above it, then welded and bolted the 2 brackets to the support next to the frame. I'll put a pic in my gallery of the brackets I made.
DieselFordLoversWife
Feb 28, 2011 05:33 PM
springteacher
1983 - 2012 Ranger & B-Series
May 4, 2010 08:54 AM
SW_601
Jul 21, 2006 09:06 AM
Jrock909
Aug 13, 2003 08:46 AM
