Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1969 f500 & 21 questions..
Old 09-18-2013, 06:32 PM
JFSPSYD's Avatar
JFSPSYD
JFSPSYD is offline
Hello all...
Recently I purchased a 69 F500 and with it many questions...that I think I am in the place.
The first is life or death of course..Do I have widow makers? Not sure how to upload photos but Id really like some opinions on this.
Second I'd like to decode the and VIN see if I can learn anything...like the winning lottery numbers?
VIN F50CCE90700
Lastly I have discovered under the master cylinder on the firewall a plastic piece and after poking my finger inside I realized this was some sort of diaphragm. After looking around I found a hose on the manifold with the broken nipple that was once a part of this mysterious piece. I fashioned a make shift connecter to attach the two thinking this might be the vacuum assist for the brakes...and what do ya know... It turns out that standing on the brakes is now a neighborhood attraction instead of a slow prayer filled rolling stop...
Can anyone tell me what this piece is called and where I might be able to find one?
Old 09-18-2013, 06:55 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by JFSPSYD
Hello all...
Second I'd like to decode the and VIN see if I can learn anything...like the winning lottery numbers? VIN F50CCE90700
Welcome to FTE
F50 = F500.
C = 330 2V Medium Duty FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
E90,700 = 1969.
Two different types of P/B boosters were used on these trucks. One is firewall (dash) mounted, master cylinder bolts to it.
Other type known as a Hydro-Vac, it's a remote mounted booster located on the left frame rail. Only the master cylinder is located on the firewall.
I asked a moderator to move your thread to the Large Truck forum, as you'll get more help there than here, as this forum is more 'pickup' orientated.
Is this the type of brake system your F500 has? If so, the part that the vacuum hose connects to on the booster (2005) is the P/B booster check valve (2B013).
Old 09-18-2013, 07:09 PM
JFSPSYD's Avatar
JFSPSYD
JFSPSYD is offline
Thanks for decoding the VIN and getting the properly located.
The booster is mounted to the frame under the drivers side. Only the master cylinder and the little plastic piece are on the firewall. I'll upload a photo now that I've figured it out.
Old 09-18-2013, 07:30 PM
NumberDummy
There are 4 possible types of F500 remote mounted Hydro-Vac systems (a pic of the firewall mounted system is in post 2).
Left upper & lower and right upper and lower:
Old 09-18-2013, 07:49 PM
JFSPSYD's Avatar
JFSPSYD
JFSPSYD is offline
Looks more like the hydraulic vaccum single system....I think... Lol
Old 09-18-2013, 07:57 PM
JFSPSYD's Avatar
JFSPSYD
JFSPSYD is offline
Here are the tires and rims..
Old 09-18-2013, 09:33 PM
JFSPSYD's Avatar
JFSPSYD
JFSPSYD is offline
and the rear..
Old 04-10-2015, 01:11 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,717 Likes on 1,402 Posts
Last edited by 85e150; 04-10-2015 at 01:12 PM. Reason: post ended up in wrong thread.
Old 04-10-2015, 01:52 PM
NumberDummy
Ed, I asked a moderator to move it here from the 1967/72 forum.
Old 04-10-2015, 02:02 PM
85e150's Avatar
85e150
85e150 is offline
I was replying to this thread:
https://www.ford-trucks.com/forums/1...ake-drums.html
and my response ended up here.
Sign of the apocolypse I guess.
Old 04-10-2015, 02:19 PM
NumberDummy
I've given the OP the drum info, but wasn't this thread originally in the 1967/72 forum?
I asked a mod earlier today to move a thread to the large truck forum, but cannot recall...now...which thread it was.
otto1990
03-05-2019 08:38 PM
farmboy555
05-29-2015 06:45 PM
cmongft
Large Truck
09-16-2014 08:20 PM
arwford
08-21-2010 04:55 PM
psonnier
09-26-2004 09:03 PM
Quick Reply: 1969 f500 & 21 questions..
