Coolant additives?
"Check coolant nitrite strength using the 3-Way Antifreeze Test Strip kit Rotunda # 328-00001 to determine if additive is required. If the nitrite strength is between 800 ppm & 300 ppm add 32 fl. oz. (946 mL) of Supplemental Coolant Additive Motorcraft VC-8 or equivalent. If nitrite strength is below 300 ppm flush & refill engine coolant (refer to Motorcraft Premium Gold Engine Coolant Change Record) – Do not add Supplemental Coolant Additive if flush & refill is required."
Regular coolant nitrite testing is absolutely required. The test interval varies from document to document, but 15k is pretty much the max. I recommend 5k while you are doing your oil change since test strips are cheap and testing only takes a minute to do.
Based on the results of the nitrite test you are likely to need to add the VC-8 coolant additive well before you reach the 60k that you should be replacing the coolant at. Some have reported nitrites down to the replace level in only 20-30k.
The dealers sadly tend to have little understanding of the maintenance requirements for a diesel engine, especially the emissions controlled ones.
