I've got troubles
Old Jun 17, 2003 | 07:39 PM
firststroke's Avatar
firststroke
Question I've got troubles
High pressure oil pump on power stroke.
The bolt I was telling you about, well I tried to tighten it and now it leaks worse, a lot worse. What the heck is it for???? I've got a picture of one and shows the bolt but I dont know how to post it? The bolt is right under the IPR cookie88 was talking about. Its at the lowest part of the HPOP you can see if you were looking at it from the drivers side. Right to tight and left to loosen, right? It just keeps tuning like its not tightening up..... HELP
99 SD Power Stroke, 4x4, Ext cab, bone stock.
Old Feb 2, 2008 | 03:39 PM
WH90's Avatar
WH90
may have to have a new one i would take it to a Ford Dealer to make sure
