leak around injector pump
Old Jul 17, 2003 | 12:38 AM
clarkprop's Avatar
clarkprop
Question leak around injector pump
I have a 7.3 non turbo with a drip while running dripping from the injector pump. where do I start, replace pump or is there a problem with the lines?
Old Feb 2, 2008 | 03:33 PM
WH90's Avatar
WH90
mine leaked to i had to replace it, i couldnt get one from Ford mine is from Napa and it seems to be working ok, but there not cheap
Old Feb 2, 2008 | 03:47 PM
PaysonPSD's Avatar
PaysonPSD
Welcome to FTE. I suggest you also post your question in the pre-powerstroke forum at this link https://www.ford-trucks.com/forums/forum117/ for more advice and check back here as well. Good Luck
