Sponsored by: Real Truck
Front bump stops
Old Sep 17, 2013 | 04:24 PM
jaydgraff's Avatar
jaydgraff
Front bump stops
I have a 2010 F-250 6.4, noticed a rough ride in the front, was looking under and noticed the front bump stops were resting on the axle, there is no gap. is this normal? I would think not seeing as there is no suspension.
Old Sep 17, 2013 | 04:26 PM
redford's Avatar
redford
FTE Leadership Emeritus
No, that isn't normal.
Sounds like something is damaged in the front suspension. Are both sides resting on the bump stops?
Old Sep 17, 2013 | 04:30 PM
jaydgraff's Avatar
jaydgraff
both side yes
Old Sep 17, 2013 | 04:42 PM
redford's Avatar
redford
Has anyone been playing "Dukes of Hazzard" with your truck? Very odd that both front springs would fail.
Old Sep 17, 2013 | 04:49 PM
jaydgraff's Avatar
jaydgraff
lets hope not, I just bought the truck less than 30 days ago, has been in ford shop for tie rod replacement, also noticed a ready lift bracket holding the panard bar on the drivers side, but not seeing any other components for a leveling kit.
I was thinking the springs were bad too. Its going into ford shop tomorrow
Old Sep 17, 2013 | 04:51 PM
redford's Avatar
redford
I've seen it before, but the spring collapse was induced by someone heating the coil springs to lower the suspension. It wasn't on a Super Duty, but the results were the same.
Old Sep 17, 2013 | 04:52 PM
jaydgraff's Avatar
jaydgraff
thanks Ive been going through front end issues ever since I bought the truck
Old Sep 17, 2013 | 05:50 PM
EXv10's Avatar
EXv10
Sounds like somebody monkeyed with it.
Old Sep 17, 2013 | 06:25 PM
redford's Avatar
redford
Thinking about it (since you mentioned evidence of a Redi-Lift was found) I bet the lift kit was removed, but the lift kit bump stops were not replaced.
Old Sep 17, 2013 | 06:57 PM
Tom's Avatar
Tom
Originally Posted by EXv10
How many miles on it? I would just get some shackles and let'm bend. They actually have some life because the bumper is about 2".
He can't get shackles for the front Brent; all Super Duties from 2005-present have coil springs up front.
If you see a ready lift bracket then it's certain that your suspension has been monkeyed with. If you're resting on the stops then this could be a safety issue, as something is definitely wrong.
Old Sep 17, 2013 | 07:18 PM
EXv10's Avatar
EXv10
Dam, that's what I get for venturing into the Super Duty forum.......
Old Sep 17, 2013 | 07:57 PM
redford's Avatar
redford
No worries. We'll only kick you out if you make more mistakes than me.....which would be difficult.
Old Sep 17, 2013 | 08:13 PM
rollerstud98's Avatar
rollerstud98
Did you buy it private?
Old Sep 17, 2013 | 08:18 PM
Bigpipes 35's Avatar
Bigpipes 35
That would be the most logical explanation, can you post any pics of the stops?
Old Sep 18, 2013 | 08:22 AM
FordService's Avatar
FordService
Official Ford Rep
...Its going into ford shop tomorrow
Let me know what you hear from your dealership, jaydgraff. If you need any assistance from me, send me a PM with your info so I can research some options. I'll need your VIN, dealer, mileage, daytime phone number, and full name.
Crystal
