weird vibration
Old Sep 17, 2013 | 08:30 AM
jfp3205's Avatar
jfp3205
weird vibration
Good morning,
My truck had a slight vibration at idle today and what i noticed the most was i was looking at the top of the motor and i noticed that the fluid in the power steering reservoir was shaking back and forth like i was shaking the container.
Is this from the vibration or is the power steering system vibrating
I have had this truck for two weeks and it has 135k on it. It is the 5.4 motor
Thanks
Old Sep 19, 2013 | 04:21 PM
1saxman's Avatar
1saxman
Spark plug or wire? Sticking valve? Loose PS reservoir? Bad fuel? Check the pulley on the PS pump - it should not be loose. The plastic pulley can break loose from the steel center. Nobody answered because there are so many things that could cause the engine to vibrate at idle. Typically we look for a 'miss'.
Laxxduck
2004 - 2008 F150
May 27, 2016 09:26 AM
LI250
Jan 10, 2013 10:23 PM
Ratfink
Dec 5, 2005 06:44 PM
2000 F-150
1997 - 2003 F150
18
May 6, 2005 11:09 AM
RedRage
Jan 24, 2005 09:49 PM
