No timing marks
Old Sep 15, 2013 | 02:43 PM
harley3348's Avatar
harley3348
No timing marks
I read all the instructions and watched all videos on using a timing light on my 1991 F150 V8. The truck has no markings, no pointer, no degree marks, nothing. What do I do now?
Please help.
Old Sep 16, 2013 | 09:33 AM
Bluegrass 7's Avatar
Bluegrass 7
Unless some one has removed the Tab or pointer your just missing them.
On the crank shaft front pulley is a line or lines denoting 0, 5 ,10 15 degrees etc.
Off the front cam cover is either a flat tab or a pointer.
It can be set up either way. With degrees on the tab or marked on the crank pulley.
Clean off the crank pulley and the tab so you can see the markings.
Apply chalk to the one with the timing marks and a bit to the pointer then lightly rub it off so what is left fill the marking.
Set a timing light up on cylinder #1.
Remove the SPOUT plug.
Loosen the distributer hold down bolt so you can just move the distributer.
Start engine let it warm up.
Align the pointer with the 10 degree mark by moving the distributer the lock it down with the bolt.
Put SPOUT plug back in and recheck that the timing has move advanced to somewhere in the 18 to 20 degree area.
you done at this point.
If you still cannot see any marks, rotate the motor so #1 cylinder is up on compression (firing). The marks should line up as well as the distributer rotor is pointing to #1 plug wire tower..
BTW even on a 97 and later 4.6 and 5.4 motors there are timing 'references' but not in the same way as the earlier motors have.
Good luck.
Old Sep 16, 2013 | 10:32 AM
harley3348's Avatar
harley3348
No Timing Marks
Thanks Bluegrass 7, I will look once again and clean off the area then follow your directions. I have noticed that not all directions given in timing procedures mention the SPOUT PLUG. What is it, where do I find it and why do you remove it?
Thanks again,
Harley
Old Sep 16, 2013 | 01:20 PM
Bluegrass 7
The SPOUT:
It is the link plug between the computer to the distributer TFI that controls ignition timing.
To set the 'base' timing the plug has to be remove so the computer cannot change the timing while your trying to set up the reference.
Find the TFI and follow it's harness and you should come to a plug and socket.
Remember the system is electronic timing because the distributer has no vacuum or centrifugal advance hardware in or on it.
Good luck.
Old Sep 17, 2013 | 07:57 PM
LxMan1's Avatar
LxMan1
Moved to correct forum.
Old Sep 18, 2013 | 07:21 AM
bashby's Avatar
bashby
That is what the spout looks like. That is just a a=random pic I got from a google search, your spout may be in a different spot.
josiewales
Oct 28, 2018 09:24 PM
can0fspam
18
Apr 16, 2018 07:10 PM
Chas1234
Jan 21, 2003 10:32 PM
pancake
Nov 22, 2002 07:31 PM
jay_1
Apr 4, 2000 05:54 PM
