Flasher
Old Sep 15, 2013 | 12:49 PM
buttwheat's Avatar
buttwheat
Flasher
A question for you guys.
My signals are flashing very quickly is that my flasher? I know in my newer vehicles it usually means that one of the bulbs is burnt out but all the bulbs are working. Thoughts?
Old Sep 15, 2013 | 12:52 PM
bertha66's Avatar
bertha66
I would replace it with a new heavy duty flasher.
Old Sep 15, 2013 | 01:29 PM
rogue40's Avatar
rogue40
+1
They're cheap.
Old Sep 15, 2013 | 01:46 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Also, there are two separate flashers, one for the turn signals and one for the emergency flashers.
Ditto on replacing the flasher.
Old Sep 15, 2013 | 03:16 PM
fmc400's Avatar
fmc400
MSEE
If a conventional thermal flasher flashes too quickly, it means the signals are pulling too much current. Incorrect bulbs could cause this. A heavy-duty flasher is load independent and would mask the issue but would not necessarily solve the problem (just hide the symptom). That is, unless the flasher itself is bad, for which a replacement would solve the issue.
Old Sep 15, 2013 | 07:46 PM
bertha66's Avatar
bertha66
If no light bulbs have been changed to start the lights flash, then IMO the flasher is the place to start.
Old Sep 15, 2013 | 10:28 PM
buttwheat's Avatar
buttwheat
Yes no lights have been changed it just started flashing fast one day.
Old Sep 16, 2013 | 12:07 AM
starwriter's Avatar
starwriter
Both directions or just one?
Old Sep 16, 2013 | 07:19 AM
buttwheat's Avatar
buttwheat
Both directions
Old Sep 16, 2013 | 07:27 AM
fmc400's Avatar
fmc400
MSEE
Sounds like the flasher then.
69oiler
Oct 29, 2017 08:11 AM
*2fords*
Aug 22, 2015 07:48 PM
HVACTOM
Feb 14, 2015 04:33 PM
deficientblair
2004 - 2008 F150
Dec 19, 2009 01:07 AM
Yeti
Sep 19, 2002 04:08 AM
