1963 F250
Old Sep 14, 2013 | 08:26 PM
Fordanatic68's Avatar
Fordanatic68
1963 F250
Hi everyone ,
New guy here.
I am looking at buying a 1963 F250, that is forsale in my local area. My main concern is that it's a straight six when I was wanting a V8. However it is cheap enough that I can convert it later on. I believe it is a 300 cube Canadian motor. The truck also has dual rear wheels, so I am guessing it is fairly low geared?
How do these travel on the highway? Will I be able to cruise at 60 mph?
Thanks in advance.
Old Sep 14, 2013 | 10:11 PM
Macs1964F100's Avatar
Macs1964F100
Not sure on the usual gearing, but the I6 300 is a hoss of a motor. Not a big block but certainly one of the finest truck motors.
Old Oct 13, 2013 | 10:47 PM
JLmissouri's Avatar
JLmissouri
I have a 63 Ford F350 with a Y block V8, I would trade in a heart beat for a 300. I would be interested in your radiator and motor mounts, and would trade for the V8 parts off my truck if your interested. I am located in northern Missouri.
Old Oct 14, 2013 | 12:03 AM
Mattrod68's Avatar
Mattrod68
300 FTW
http://www.ebay.com/itm/HOLMAN-MOODY-ALUMINUM-FORD-INLINE-6-INTAKE-MANIFOLD-FOR-240-AND-300-/310767652220?pt=Motors_Car_Truck_Parts_Accessories&hash=item485b320d7c&vxp=mtr
Old Oct 14, 2013 | 04:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Fordanatic68
I am looking at buying a 1963 F250, that is for sale in my local area. My main concern is that it's a straight six when I was wanting a V8. However it is cheap enough that I can convert it later on.
I believe it is a 300 cube Canadian motor. The truck also has dual rear wheels (DRW's), so I am guessing it is fairly low geared?
Welcome to FTE
No such thing as a Canadian only engine, same engines used in the US & Canada.
300 (and 240) I-6's introduced in 1965 .. intake/exhaust manifolds located on the right (passenger *) side.
223 I-6 standard equipment engine 1961/64, 262 I-6 optional 1963/64. Intake/exhaust manifolds located on the left (drivers *) side.
No F250 was available with DRW's until 1985 .. so it's been converted (by whom and from what?) to DRW's.
The F250's rear axle is a Spicer/Dana 60, the ratio could be 4.10/4.56/4.88-1. Conversion may have included an F350's Spicer/Dana 70 rear axle, minimum ratio: 5.13-1.
IMO: PASS! 1961/64's have front leaf springs, ride and steer like oxcarts. The fact this is a DRW conversion will cause problems if parts need to be replaced, as who knows what they're from.
The only V8 that can be easily swapped is the 292 (1957/64), as it mounts the same way as the 6. If wanting any other V8, expensive mounting kits are your only choice.
1965/66 F100 2WD's far better choice, have coil spring front suspension. Myriad different V8's can be swapped from other trucks.
P/S and disc brakes can be swapped from 1973/79's, while 1961/64's require expensive aftermarket kits.
And, are you sure it's an F250? F250's have 8 lug wheels on a 6.50" bolt circle, while F350's have 6 lug wheels on a 7.25" bolt circle, were available with SRW & DRW.
* Driver & Passenger side refers to US/Canada, where we drive on the correct side of the road. UK, Down Under, South Africa, Japan and etc drive on the wrong side of the road.
Old Oct 14, 2013 | 07:33 AM
CropDusterMan's Avatar
CropDusterMan
PASS. If it's not an actual 350, it's totally "frankenstein'd".
jmc0369
Jun 13, 2010 09:39 AM
Onus
Feb 7, 2010 01:18 AM
Sam_Fear
Nov 21, 2006 01:26 AM
Mikes67F250
Mar 16, 2005 08:20 AM
trouble
Nov 28, 2002 09:20 PM
