confused
Check the timing. Take the spout connector loose and check it.
Check the throttle stop setting. The engine should barely run or die when you pull the connector off the IAC after the engine is warmed up.
By | 2026-06-09 11:10:08
By | 2026-06-09 10:53:36
By | 2026-06-08 18:50:34
By | 2026-06-05 12:58:01
By | 2026-06-03 09:51:16
By | 2026-06-03 15:43:58
By | 2026-06-03 11:38:36
By | 2026-05-27 16:24:34
By | 2026-05-27 16:17:28
By | 2026-05-18 19:34:33
