Rough ideling 86 5.0
My 86 has a rough idel and I have done the following
1 replaced plugs cap wires rotor,
2 ran Redline fuel treatment and replaced fuel filter
3 oil coolant thermistat
when I bring it above an idel is runs great but idel it kinds (lopes)
and revs up and down +-300RPM
Dustin
Dustin
TPS or the ACT sensors....is the temp gage warm and then after driving it, the temp gage shows below the normal heating range? The Trottle position sensor could be a problem, but its tough to get to...well the ACT sensor is too but its manageable to me.
Mine did these and it corrected the surgeing, but now its has a slight miss after 3rd..engine wants to bog down under a load. Next will be the MAP sensor to see if its going to help it. ALready replaced the ICM (idle control Modual)...
