Trans problem
Old Sep 14, 2013 | 05:14 PM
lew52's Avatar
lew52
Trans problem
I have a 2004 f 150 5.4 auto , when i first start off in the morning i get a trans malfunction on the dash , od light flashes , and the speedo stops working right , after i shut it off and restart its fine the rest of the day , vss ? , any thoughts , and is this located on the trans or rear end ....
Old Sep 15, 2013 | 12:09 PM
sandrat's Avatar
sandrat
If you have the codes checked and it ends up being a VSS code, check the wiring real good at the larger connector on the outside of the frame rail, approximately under the driver's door on the left side; the wiring from the ABS module to the sensor runs through the connector and it's prone to corrosion. There is a black plastic cover that goes over two connectors, pull it off & unplug the connector, make sure it's clean.
Old Sep 16, 2013 | 11:54 AM
lew52's Avatar
lew52
Thanks sand rat , i think that did it , no problems yesterday or today.....
Driven71
May 27, 2015 05:11 PM
Driven71
May 25, 2015 06:27 PM
lew52
Sep 15, 2013 07:21 AM
rickwhis
Sep 9, 2013 07:55 PM
jbaynor
Dec 23, 2012 09:28 PM
