problems with towing trailer
Old Sep 13, 2013 | 04:46 PM
mduvalsr's Avatar
mduvalsr
I have a 1999 ford f350 dually that is used for mainly towing a fifth wheel trailer. When the air conditioning is turned on the compressor seems to kick on and off every few seconds. Thinking it was the fan clutch, I had a new one installed but the problem still remains. When not towing the air conditioner works fine. Have taken it to several ford dealers and the ac checks out fine. When towing if i shift into od the problem goes away. It seems that it happens when the engine is under a load that it happens. Any thoughts would be appreciated.
Old Sep 13, 2013 | 05:14 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Don't know how the load would affect it, but is the air gap correct?
Old Sep 13, 2013 | 06:32 PM
mduvalsr's Avatar
mduvalsr
air gap has been checked by several dealers
Old Sep 13, 2013 | 09:14 PM
carltonwebb's Avatar
carltonwebb
Is there a lot of debris between the radiator and coolers? It could cause it to not cool as efficiently and cause your issues.
Old Sep 13, 2013 | 09:15 PM
jeffreyt's Avatar
jeffreyt
It's worth checking the connector, I've seen them wear out and make intermittent connection.
Old Sep 13, 2013 | 10:20 PM
mjtpolice76's Avatar
mjtpolice76
High pressure switch the connector gets loose 28 bucks at rockauto an just splice it in
Old Sep 16, 2013 | 10:45 AM
good9682's Avatar
good9682
Mine does the exact same thing, I'm curious if the high pressure switch fixes it.
Rob_17
Feb 8, 2021 11:55 AM
johndeerefarmer
Oct 15, 2016 11:52 AM
rjdpowerstroke
May 20, 2009 05:42 PM
cetmanhd
Aug 28, 2004 09:27 PM
dusty
All Things Towing
Sep 26, 2000 11:21 PM
