Glow Plug Codes/ Issues
Old Sep 13, 2013 | 08:39 AM
HAMMERDOWN103's Avatar
HAMMERDOWN103
Question Glow Plug Codes/ Issues
So about a month ago I changed all my glow plugs and last week changed the uvch on both sides. My truck had the old style connectors and the new ones have the upgraded support where the $0.50 mod normally goes. Here is my question, now I'm getting the glow plug codes for the whole passenger side 1-3-5-7 but it starts and runs fine. Last time just dropping #2 would make the truck shake and shudder. Is there something else down the line that could trip these codes? Thanks in advance!
Old Sep 13, 2013 | 10:03 AM
woodnthings's Avatar
woodnthings
You must have a California truck. You may have a bad GPCM or you have a connector issue. You can look over the whole system and make sure all the connections are clean and fully engaged.
Also, a bad glowplug won't make the truck run rough.
Old Sep 13, 2013 | 01:26 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by HAMMERDOWN103
...now I'm getting the glow plug codes for the whole passenger side 1-3-5-7 but it starts and runs fine.
That's where I'd put my money too. Bad GPCM.
Stewart
Old Sep 13, 2013 | 01:55 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
I agree with the above posts. Definitely GPCM related.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Sep 14, 2013 | 09:11 PM
HAMMERDOWN103
How would that be a California thing? I'll have to check the connections and hope that fixes it.
Old Sep 15, 2013 | 01:54 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Only CA emissions trucks came with the GPCM, others just used a standard relay.
Also, just make sure the valve cover connectors (inside and out) are connected, especially if you are having a rough running issue.
Any CEL?
Old Sep 15, 2013 | 03:37 PM
HAMMERDOWN103
CEL? D@mm California BS .... Truck doesn't run rough or anything. I forgot to mention there was an injector code before and that is why it wasn't running right. Fixed that with the new modified harnesses. This was the first time an entire side threw codes .... Have a volt and ohm tester just need some time to test everything.
Old Sep 15, 2013 | 03:45 PM
Stewart_H's Avatar
Stewart_H
CEL?
Check Engine Light. Same as Service Engine Soon (SES) light.
D@mm California BS
Eh, one could say that. However, Ford stopped using the GPR completely and went exclusively with the GPCM starting with the 6.0L PSD.
Glow plugs not working will create a hard start issue and rough chugging when the temps are really cold, but otherwise you won't experience a rough running engine like you would if the UVCH was out on one side.
Stewart
Old Sep 15, 2013 | 11:11 PM
HAMMERDOWN103
Yes the CEL is on. Doesn't start any harder but I don't think it gets below 60 at night right now. Closer to winter it gets into the 30s. And no rough running either.
rtignor212
6.7L Power Stroke Diesel
Oct 9, 2017 06:58 AM
jetlr1
Oct 3, 2014 02:25 PM
gporonsk
Mar 10, 2012 12:33 PM
ridgebackphatty
Jan 26, 2006 12:37 PM
