I have a '74 F250 with 390 engine and a 4bbl carb. I have been having problems getting the thermostat cover to seal properly. When trying to purchase a new one from Napa I get a thermostat and cover that are smaller in diameter than the one I have currently. The existing thermostat has about 1/16" overhang on the intake.
How do I find out which thermostat and cover is correct?
I have an FE thermostat and housing in front of me...
The thermostat is two inches in diameter and fits on the housing which has a slight relief to account for the thermostat's flange. The correct order of assembly is intake-gasket-thermostat-housing - bolts.
The thermostat I have is 2 1/2" in diameter and the intake opening is 2 3/16". The housing does have the relief for the thermostat flange. It seems what I have is larger than stock. Any idea on how I can figure out what engine the intake came from?
The necks are different ,some have place for the thermostat to "screw in" .
I found a thermostat of a newer Chevy that was the right diameter to fit in the neck .
Tell you what... bust out your receipt and go to Napa's web site and cross-check the part numbers. They could have given you the wrong ones. Next time you go to the parts store, bring your old thermostat and housing with you to compare on the spot.
I got a new thermostat by bringing in the old one, the guy lucked out and found one that was the right size. Makes me wonder if it is the right temp...
Cast number on intake is C5AE 9425 C
The temp spec is usually stamped on the flange.
Based on Montana's input (welcome back by the way) it's an early intake thus the larger opening.
