batteries
Old Sep 12, 2013 | 04:19 PM
2002exPSD's Avatar
2002exPSD
Originally Posted by LivingLarge
I've always used the Motorcraft, however on my last purchase I put in the 850cca. They were leaking a little bit and my positive side terminal was always turning green. Dealer replaced after just 2 months and 2 months later I was seeing the green again. Finally I went back to the 750cca Motorcraft as the Parts manager requested and had no issues after that.
My new to me EX has 2 NEW no name 650cca in there now, all is good but will be changing before my winter trip.
I'm going to give the Diehard Platinums with 930cca a try.
Are you using no-ox on your battery connections? Will never corroide or oxidize. I am required to use it by AT&T on all their electrical connections at their cell phone towers.
Old Sep 12, 2013 | 04:49 PM
LivingLarge's Avatar
LivingLarge
No, at the time the dealer recommended some type of pad that sat under the terminals. I thought this was just a way of them masking the problem, but the parts manager said that I was overcharging the 850cca battery and that the 750 cca was a better fit for my application (At that time I was running a high output alternator) to this day I don't know if that really had anything to do with it. But the proof was in the pudding, no leaks on the 750.
I'm not saying I wouldn't do the Motorcraft again, just want to try the Platinums this time around.
Old Sep 12, 2013 | 05:43 PM
2002exPSD's Avatar
2002exPSD
Those pads suck and don't work. Buy a bottle of no-ox at Home Depot in the electrical section. Looks like a bottle of Elmer's glue.
Old Sep 12, 2013 | 05:49 PM
LivingLarge
Haven't had that problem in over a year, but will note it thanks.
Old Sep 12, 2013 | 05:58 PM
ycis's Avatar
ycis
I use corrosion-x on everything thats not painted or powdercoated...especially in a marine environment.
stuff is great...and easy to coat on things since its in a spray can.
also smells like pancakes =)
Old Sep 12, 2013 | 07:08 PM
Stewart_H's Avatar
Stewart_H
Yup.
Been using that stuff for years, ever since I saw a post by my fellow moderator megawatt00 (he's an electrician) recommend the stuff.
Stewart
Old Sep 12, 2013 | 08:57 PM
2002exPSD's Avatar
2002exPSD
Originally Posted by Stewart_H
Yup.
Stewart
Yep I love that stuff. Cheap at Home Depot. $27 a bottle at electrical shop I buy my materials from. Use it on every single connection I do.
Old Sep 13, 2013 | 06:57 AM
bcrewcaptain's Avatar
bcrewcaptain
Wal-mart batteries here, largest I could fit, 2 in the truck, both trailers have one for the winch and the camper has 2 matching ones as well. If I do need to do some emergency battery swapping, I'm never far from one.
Plus it's never hard to find a wal-mart should I need to do an exchange
Tampa250
Jul 31, 2017 09:23 PM
jeeplj8
Feb 3, 2011 03:42 PM
ExpySport
Electrical Systems/Wiring
Nov 16, 2009 10:28 PM
02GrayPowerStroke
Jan 25, 2007 03:29 PM
American Muscle
1997 - 2003 F150
Dec 13, 2002 12:09 AM
