Yes.. in a turbo motor, but without the blower it won't make any useable power below 3000rpm and head flow will limit peak HP so it's gonna have a powerband like a 125cc dirtbike.
Replacing a glass pack with a chambered muffler isn't much of an improvement. No cam mods to a NA motor are gonna help performance a meaningful amount, but it will hurt overall usability. It's a lose-lose situation, spending money to make your truck run worse. It will pull a little better up top, but that's not very useful.
So what cam would provide the most torque from 2,000 to 4,000 rpm's in a N/A 2.3 Ranger, stock cam or aftermarket cam? I changed the gauge cluster to one with a tach to just see what the engine is actually doing. Looks to pull at around 2600 and I'll shift at about 3600. 5 gear doing 65 it turns 2500. Just save my money on the cam and buy a adjustable cam gear or what. What do you experts think, all opinions welcomed.
It appears the stock cam in this motor is as I suspected, not enough lift or duration to let the motor breath effectively.
Intake Duration: 187/248 deg at 0.050"/seat to seat.
Intake lift: 0.390" or 0.402"
Exahust Duration: 189/250 degrees at 0.050"/seat to seat.
Exhaust Lift: 0.390" or 0.402"
The problem it appears is that all available aftermarket cams seem to jump all the way up to 270/280 seat to seat duration which pushes the powerband way too high for street use. What you want is a cam with something like 255-260 deg seat to seat duration(195-205 @ 0.050") and 0.450- 0.480" lift or whatever the valve springs can handle without binding, but you may need to get that custom made.
FWIW the stock cam in the '87-91 5.0 truck motor has similar specs and it produces a similarly weak 0-3500rpm powerband. Simply swapping in a cam with about 260 seat-seat duration and 0.450" lift produces dramatic power gains across the board and tons more topend horsepower.
I think I might go with the Crane Cam RFOR-214/420-12, 214@.050" for intake and exhaust, .420" lift and 112 LCA. I think that will be the best cam for my truck, should pull like a freight train with the 4.56 gears. Let me ask this though, you think its possible to squeeze 130 hp out of this engine without turboing?
The German made 2.0 litre version of the 2.3 made 120+hp stock in early seventies Mercury Capri's and Ford Pinto's
It should be NO problem to get that and more out of a 2.3
I think those are bad comparisons. It is much easier to produce power without powerband compromises with DOHC configurations than with a SOHC configuration.
Can you reach 150hp NA, absolutely, but you will have to sacrifice one part of the powerband (low rpm) to do it.
There are DOHC heads that you can use. The cost of a swap becomes a serious issue. Another consideration is that many small displacement high output engines are built to produce power by being able to not only rev higher, but to flow at higher RPMs.
Hitting 130 hp should not be a problem, that's only a 20 - 30 peak increase over stock. Still, to get it you may have to give up some torque, and you are probably going to need to tune, since I doubt the stock tuning can adapt enough.
For the record the high compression version of the 2.0l used in the Pinto only produced 99hp, you have to make sure you aren't confusing kw ratings and hp ratings when comparing engines.
Great gas mileage, and the power of a V8! Isn't that what everyone wants?
If it could be done, it would be. Any increase in low end torque comes at the expense of high end power, in general.
Why not get hold of an eco-boost and plumb that into place? Has anyone done that? "Power on demand" from the engineers first pencil on paper. Seems like a natural fit to me, but with a lot of plumbing and wiring work necessary.
If it would fit, as I have said before, the 200 small six would be a great engine in the Ranger. Someone did one, but the radiator ended up behind the cab, if memory dredged up the right thoughts.
tom
I weighed my trailer today and tipped the scales at 1,050 lbs. With the mower, 2000 lbs. I know its a small truck with a small engine but is it normal to struggle with that much weight?
There's absolutely no reason a 2.3L shouldn't make 150hp, I got a all stock non turbo Subaru 2.5l that makes 160hp.
Ford's past history with trucks is to sacrifice high RPM power for low RPM torque. Until only recently (five years?), you've never seen an HO version of their engines offered in the trucks. Most trucks are meant for some kind of "work", and if you want to pull trailers, you wouldn't normally expect a four cylinder version to do the job satisfactorily.
So hopping it up and gearing it down will improve things, but people shouldn't go sniveling that it doesn't make enough power. It was never intended to!
I clearly remember in the 1971 Ford shop manual that accompanied my friends 71 Mercury Capri, that the 2.0 German made engine put out 120-122hp not kw.........Yes, I may be getting old, but I ain't senile.
I have to disagree with that to some extent, they were still thinking with the 80's mentality where the best(most profitable) way to reach the emissions and fuel consumption goals was to restrict the motor so these early EFI versions were nowhere close to making the torque or horsepower that they could. I have been working with this vintage truck for some time now and there was lot of potential left on the table. All stock the early EFI 5.0 truck motor could barely maintain highway speed into a headwind and you were lucky to get low teens fuel milage, but with a few simple upgrades to let it breath(cam and exhaust) I have seen 18+ mpg highway and a ton more power across the board. Now obviously there isn't as much potential in a 4cylinder with less than half that displacement but there is still room for improvement.
