6.2L V8 Discuss the 6.2L V8
Tranny temps.
Old Sep 28, 2013 | 09:54 AM
ATP Pilot's Avatar
ATP Pilot
Originally Posted by Delawhere?
ATP Pilot- I really like the way you have the scangauge mounted. My question to you and others with any gauges like this, does this have any effect on the Ford warranty? Is this a tuner of sorts, or is this just a way to read the mpg and temps of the engine and trans? I am planning to buy a new 6.2L shortly with the Lariet pkg. Does it have these gauge readings built in to the dash or does the scangauge give you more than the factory gauges? Lots of questions, hope someone can clear those up for me.
Thanks
Its not a tuner, just a reader :
ScanGaugeII : Linear Logic - Home of the ScanGauge
Places like this, if you look around, sell the combo of the scangauge and mounting kit http://store.blendmount.com/scangaug...-kit-p102.aspx
Old Sep 29, 2013 | 08:25 PM
Delawhere?'s Avatar
Delawhere?
ATP Pilot, Thanks for the info, this looks like a nice guage set up, and I'll be checking this out. Do you have to make any connections to the tranny pan or is this all done through the onboard computer? When I had my guages done in 05, I had to get the Pyro temp drilled into the manifold and the trans pan had a connection made at the pan itself, so just wondering if all this is necessary. I will look at the info and see if that answers the questions. Thanks again.
Nice Work Truck
Nov 13, 2011 10:45 AM
BJB6521
Jul 18, 2007 11:00 PM
stutterstan
Mar 26, 2005 04:30 PM
cgl
Oct 6, 2003 07:27 PM
