Gracias!
I picked up a set of UVC gaskets with the wire looms. I'll OHM both harnesses through the 9 pin connectors to see if the one's I have installed are still good and keep the new one's for backup. We'll see tonight.
Tugly-
I've been using this forum for about a year and it's by far the best for helpful info & tech. In that time the majority of usful info & friendly threads have had plenty of feedback from you. I'm sure you've delt with this seemingly simple issue with countless memers, so thanks for your taking the time to help one more with it.
Thank you for the kind words! I'd be in the tall weeds, were it not for the support of this forum.
About that making babies thing... had enough yet? [/FONT]
Yeah this forum doesn't have the "keyboard trucker's" with bigger ego's than brains like some other forums have.
As for the rodents, having 3 kids is NUTS! worth it but nuts. I've learned my lesson though, I modified "nature's way" last month no more suprizes for this guy. I see my kids as expensive pets, it helps LOL.
Back on topic, I pulled my wiring harness that lays over the motor from the 39 pin connector to all the sensors. I did this for ease of maintenance. I'm going to inspect it all and clean the oil off of it. Is there anything in particular I should pay close attention to while inspecting it? Before I wire it all back up I'll spray out all the connectors with contact cleaner and lube them up with die-electric grease.
