column shifter
Old 09-11-2013, 09:55 AM
skotyg's Avatar
skotyg
skotyg is offline
column shifter
Does anyone know where I can get the column shifter for a 56 f 100? The po had switched to a floor shifter and I'd like to switch back to the column shifter.
Thanks for any help!
Scott
Old 09-11-2013, 08:28 PM
flattie39's Avatar
flattie39
flattie39 is offline
Column Shifter
Scott - Will one out of a 54 work for you? I just installed a T-5 and am ready to pull the column shifter out. Ken
Old 09-12-2013, 07:59 AM
skotyg's Avatar
skotyg
skotyg is offline
Hi Ken
I think it would. Let me know what you want for it! I've
had a tough time finding one.
Thank you!
Old 09-12-2013, 08:33 AM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is online now
Phantom of the Phorum
The original steering column in the '56 is shorter than the '53-'55. I forget how much, but it's like an inch or so.
The '56 has the dished steering wheel, while the '53-'55 is almost flat.
Please don't hurt the messenger!
Old 09-12-2013, 09:20 AM
flattie39's Avatar
flattie39
Column Shifter
Thanks ET - I'll just add that info to the long, long list of things I don't know about F100's but am learning on this forum.
Scott - If you decide you can modify it to fit, I'll bring it with me to the AutoFair in Charlotte next week. We have 4 spots in the Blue field that we've had for over 20 years. Ken
Old 09-12-2013, 12:21 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Not only is the steering column 1956 only, but so are the two shift rods that attach to the manual control selector levers on the column, then to the shift arms on the trans.
Attempting to locate these two 1956 shift rods might be almost impossible.
Pic from 1948/56 Ford Truck Parts Catalog (available on a CD from hipoparts.com) C (F100) & D (F250).
Old 09-12-2013, 02:14 PM
skotyg's Avatar
skotyg
skotyg is offline
Hi guys
I just wanted to make sure I'm calling it the right thing. I just need the arm that comes out of the column. The one you actually hold while shifting. The column is fine, just missing the arm itself.
Thanks!
Ken I'll let you know if I can get out there. I work weekends and will be out of town during the week but may be able to get out there!
Old 09-12-2013, 02:18 PM
skotyg's Avatar
skotyg
skotyg is offline
#7210 on the diagram
Old 09-12-2013, 02:40 PM
EffieTrucker
Originally Posted by skotyg
Hi guys
Oh, in that case the only real differences are the '56 has a slight bend in it (because of the dished steering wheel) and a long ****, while the '53-'55 is straight with a round ****.
The earlier handle will work, but it's going to be just a little further away from your steering wheel. About an inch or so.
Old 09-12-2013, 04:30 PM
NumberDummy
B6C-7210-C .. 3 M/T Shift Lever-approx. 11 1/4" long / 1956/60 F100/350 - 1961/63 Econoline - 1964 Econoline before serial number 480,001 / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has ONE = 800-476-9653.
ANTIQUE AUTO SUPPLY in Arlington TX shows TWO (817-275-2381), but webpage on partsvoice.com last updated 6/29/2012.
Old 09-12-2013, 04:45 PM
EffieTrucker
Here is a side-by-side pic. The one with a steering wheel and straight shift lever is the '53, the one without and bent shift lever is the '56.
The '56 column isn't that much shorter, they're not lined up exactly. The difference is more like 1 3/4" to 2".
Old 09-12-2013, 06:08 PM
skotyg's Avatar
skotyg
skotyg is offline
Thanks for the help! Dennis Carpenter is very close to me
Thanks again!
Glens67
13
08-07-2021 08:29 PM
emeraldcoupe
04-01-2016 04:38 PM
Brother F
07-23-2012 07:59 PM
61ford
10-21-2005 08:58 PM
Quick Reply: column shifter
