Exploded view of the 56 column shifter? - Ford Truck Enthusiasts Forums
Old 04-16-2018, 04:16 PM
Glens67's Avatar
Glens67
Glens67 is offline
Glens67 is starting off with a positive reputation.
My column 3 speed shifter 1956 F100 is stiff up and down. Is there an exploded drawing for it?
Thanks
Old 04-16-2018, 08:53 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Upper pic .. C = F100, D = F250
Old 04-16-2018, 10:11 PM
Glens67's Avatar
Glens67
Glens67 is offline
Thanks Bill!
Old 04-16-2018, 10:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Take a look at this article, it shows the pieces in more detail. Hard shifter action up-down probably means the linkages aren't adjusted correctly, or you need to lube the shifter assembly on the bottom of the column (there's a zerk there).
File Type: pdf
Old 04-17-2018, 12:12 AM
Glens67's Avatar
Glens67
Glens67 is offline
Ross
thank you very much!
That helps alot!
Glen
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
