Rear antilock?
Old Sep 14, 2013 | 07:20 PM
BruteFord's Avatar
BruteFord
I agree with many of the above, I much prefer the control of not having ABS. I know how to threshold brake and it's been shown to have better stopping distance. ABS is for panicky women that can't drive. It would be really nice however to have some brake proportioning for load weight differences.
Originally Posted by bigberthasdad
according to my Ford book the light comes on when one side is getting less pressure than the other.I.E. leaking wheel cylinder or uneven brake wear.The solution is to fix the issue then to have an assistant pump pedal as if you were bleeding the brakes but you crack the lines as the pedal depresses if you have the right line cracked the light should go out. At the exact moment the light goes out you need to tighten the line and stop depressing the pedal.There is a needle inside the valve that needs to be centered this is what activates the light.
Uhm no, there is nothing in the RABS system that is left right. There is one speed sensor on the ring gear, and one valve that pulses BOTH rear wheels at the same time.
Old Sep 14, 2013 | 08:22 PM
BigBlockF350's Avatar
BigBlockF350
Yep, the same reason we have big brake boosters too, haha. For the soccer moms
Old Sep 14, 2013 | 09:01 PM
BruteFord's Avatar
BruteFord
FWIW it's one of my biggest complaints about new cars. Overly powerful brakes with ABS and no feel if you know what I mean. And power steering with fake resistance in an attempt to add some sporty feel that just ends up removing all steering feedback.
I would hate to drive my F350 without power steering or power brakes but ours has the right feel. On the other hand I see no point in a mid size or smaller car having power brakes or steering, they don't need it, and it just ruins the handling.
In order to threshold brake and steer you need the feedback in the brake pedal and steering wheel without it you might as well drive by remote control.
I've driven/owned everything from old full size heavy duty trucks to little sports cars without power steering or brakes and while the trucks could have been better my jeep and all my cars except my 65 T-bird were much better off without that stuff. But I doubt it's even possible anymore to buy a new car without power steering and brakes.
Old Sep 14, 2013 | 11:35 PM
JReagan90's Avatar
JReagan90
I've had the same problem with the RABS on my '92 flare side. I replaced the RABS sensor located on the top of the differential, but that didn't do anything to fix the problem. It's not something I notice often, but in moments just like today where somebody decided to lock it down in front of me and my rear end slid into the opposite lane... that's when I think having my rear abs working wouldn't be so bad.
Old Sep 15, 2013 | 12:51 PM
BigBlockF350
Wow, even when I've locked mine at high speed I've never had any issues with sliding out with my truck. I obviously try not to lock it up, but even when I has it stays straight.
Old Sep 15, 2013 | 01:57 PM
tjc transport's Avatar
tjc transport
i ain't rite
that sounds like improperly adjusted rear brakes, not an abs issue.
all my vehicles will track straight as an arrow when i lock up the brakes.
Old Sep 15, 2013 | 02:01 PM
BigBlockF350
Agreed completely. My truck also tracks straight if I lock the brakes.
Old Sep 15, 2013 | 03:33 PM
Nothing Special's Avatar
Nothing Special
My '95 usually tracked straight in a full-on panic stop. But with the RABS what would happen was the front wheels would lock and the rear would keep rolling (unless I backed off the brakes to unlock the front, which I usually did).
But one of the two odd situations where it didn't track straight was on a snow-covered dirt road. The road was crowned and the skidding front tires started downhill toward the ditch. That turned the truck toward the ditch and the rolling rear tires just followed happily along. All 4 wheels locked would have made the whole truck slide sideways toward the ditch, but without turning to point into it. So the RABS didn't really make anything worse, it just was unexpected compared to no ABS or 4 wheel ABS.
The other odd situation was when I nailed the brakes when I was already in a spin. The front wheels locked and started going in a straight line in the direction I was basically going. Meanwhile the rolling rear wheels didn't want to go sideways, so they straightened the truck out. Almost immediately the spin was corrected and I was tracking straight ahead. Cool!
Old Oct 21, 2013 | 06:07 PM
NeoCowboy's Avatar
NeoCowboy
Question
On the same subject of the RABS valve, anyone know where to get the fittings for this? The line from my master cylinder to my control valve rusted out and when I tried to pull it off I stripped the fitting on the line. I ended up pulling the fitting from the valve control valve and even with the fitting from the line in a vice and a wrench on the fitting from the valve I just keep turning down the line fitting without it breaking free. I don't want to drop $135 into a new control valve just because the line rusted.
Thanks
Old Oct 21, 2013 | 06:16 PM
BigBlockF350
Thanks
Go to a NAPA store. Bring them an example of what you need, describe it to them, and they'll probably be able to hook you up with the correct fitting.
My NAPA store has been great with hard to find items and custom hoses and stuff.
Old Oct 21, 2013 | 06:28 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
This light was on when I brought My '87 F250 home, I topped off the brake fluid, and it went right out
Old Oct 21, 2013 | 09:50 PM
Truck Guy99's Avatar
Truck Guy99
That's a good point. I didn't even think to check the brake fluid. I will do that and report back.
Old Jan 17, 2014 | 06:08 PM
  #28
Slingnsteel's Avatar
Slingnsteel
Heyas
Here is what happens with my RABS. The light has always gone on/off randomly. The truck has always stopped fine but was a little weak wich only meant I pushed farther. I think the problem was the rear brakes were not agjusted properly (tight enoug). I did my front Ujoint the other day and compressed my brake caliper with a vice. I drove the truck and when I hit the brakes it would stop with a tap of the brakes and I heard a swoosh coming from the floor wich sounded like a vacum leak coming from what I think is the master cylinder. I did adjust the rear brakes and bleed all brakes and RABS in proper order. It still did the same thing. I imagine debre got into the RABS but do not no for sure. I got under the truck and hit the RABS with a hammer and it seams to be better. Someone spoke about a spring, is it located on the top end of the RABS and can I take it out and put back in while still on the rail? I have front airbag frame over one of the bold that holds the RABS wich would be a pain to remove.
SM
Old Apr 2, 2014 | 12:33 AM
  #29
Truck Guy99
How does the brake pedal feel? Soft, squishy, hard, fairly firm? Can you feel/tell if the RABS works when you stop hard? A lot of times the RABS will will quit working properly and cause a bad pedal feel and it'll be soft/squishy.
I know this thread is old, but I had a scare recently. There is no abs and the pedal is squishy like you describe. I was recently driving around a blind bend and I pass a sign that says the speed limit is 50. I look down at my speedo and it says 40, so I know I'm good. I look up and I'm almost to a stop sign. I floor the brake pedal and I feel the brakes lock up. I start to pump the brakes and I screeched to a halt just at the stop sign. I narrowly miss a brand new suburban full of kids. I know this truck is huge and it won't stop on a dime, but it took a lot longer to stop than it should have. This is unsafe and it will be addressed immediately. I will soon try the stuff you mentioned and report back. Thanks for your help
Old Apr 2, 2014 | 12:34 PM
  #30
dixie460's Avatar
dixie460
Good job getting her stopped but I don't think having RABS would've helped.
All antiskid does is make sure you don't spin out if you're braking in a turn. It does NOT reduce braking distance compared to a good driver using threshold braking.
The trick is to not release the pedal completely... everyone says pump it but that's why your braking distance goes up. Mash that sucker down til the wheels lock up, back off just enough they start rolling again, and that's all the braking you're gonna get. RABS or even 4 wheel ABS does the same exact thing... dumps brake pressure off til the wheels start rolling again, then maintains that level of brake application.
