Fuel Cell in bed? Thoughts?
I kind of agree with him though. Boxing a frame, beefing up crossmembers, sometimes that puts stress in areas that weren't designed for it, and creates other problems. I had done some research and reading about it a while back, when I first got my F150 crew cab. Because the frame was stretched by Centurion, there's a whole lot of flex going on at the bed. Kinda worried me a bit, but I ended up just plating the outside rails.
I read enough about boxing to realize that I probably didn't need it, and more importantly, I didn't want to put stress on any areas that weren't designed for it.
The whole reason my bronco got a cell was because I dropped off a ledge and caught the back of my tank, ruined my wheeling trip since it wouldn't hold fuel anymore. I had been thinking about doing it for awhile to improve my departure angle anyway.
Technically the DOT doesn't allow any fuel tank to be attached to the engine that can allow gravity feed.
As far as stiffening the frame. What material were you going to use. Mild steel when bent will stay that way, the heat treated steel frame will twist back by itself. If you box or plate the frame then you are hindering the flexing aspect of the frame and if flexed too much, it will stay twisted. I had a ranger v8 that I had built for Offroad, after I put 38s on it I broke the crossmember rivets and pulled truck apart and beefed it up.... Then when I ran out of articulation getting pulled out once, frame was bent and didn't go back. Oops. I straightened it and completed my reinforcing with heavier material and did the complete frame this time, and had zero issues after.
If you're going to strengthen frame, make sure you remove all the flex, because you'll create high stress areas where the original frame meets the reinforced section. Now I have a full size f250 supercab longbed with about 8" lift and 40s. Check out my website in signature. It's nothing special. Just say you want to reduce flex so you don't rip cab mounts out like I did. Too much beating and too much flex.
460 4spd, 350 gears, welded rear diff, low range, 3rd gear at 5-6000rpm.
Brad is one of the most respected and knowledgable members of the forum. He can defend himself, but if you want to see he correct way of reinforcing a frame, he is doing it on his badass diesel as we speak. Proper material for the application and no detail left untouched as usual more than likely.
Problem is the ones with ford sending units are significantly higher cost usually.
If you don't care about knowing fuel level, get a cheap one. Just look and you'll see. Summit is easy to look stuff up at.
Any fuel cell will work.
But it is your truck. Go box it, then nothing will bolt on like it was designed, it will trap dirt and moisture then rot out. And Like Untamd said,it will most likely bend and not bend back
This is just a PIPE DREAM on your part. You can't even UNBOLT a fuel tank, so what makes you think you could plumb and or wire a fuel cell or box a frame.
You are PATHETIC
Let us NOT FORGET this thread https://www.ford-trucks.com/forums/1...c-apology.html
You are PATHETIC
No one said i couldnt unbolt a fuel tank. Not once did i say that. I said i cant drop it because i have a home built hitch that is welded on the frame under the tank.
And i cant plump or wire? Please. I just got done plumbing my whole engine with AN fittings and stainless lines. I litterly made my own wiring harness off of RJM's write up.
I may ask for ideas and have stupid thoughts every now and then, and its usually when Im stumped at 3am, but that doesnt mean you can go attack someone for asking.
P.s. Your a cop if I remember? Example A why firefighters hate cops. There ******.
You are PATHETIC
mud truck beating - YouTube
Broke engine mount, blew ps pump, and clutch slave gave up. It loved every minute of the abuse. I drove it the rest of the day and in another mud hole twisted it so the steering shaft come out of its tube.
Fun times.
Sorry, dont see ONE mention of a hitch being welded on.
Thanks. A hole is my middle name. People who STRICTLY wheel their truck box their frame, but they also know how to remove a fuel tank. Untamed explained why
Again, dodnt see anywhere it said anything a bout a hitch being the problem
Who is attacking?(O that is right , YOU are the one calling names) Mearling stating a FACT. No need to box your frame, and you were flat aout LIEING in yout 1st thread on here and came up with som BS story trying to cover your tracks
Sorry, no cop here. Again, the name calling.
Also. The title to this thread is "fuel-cell-in-bed-thoughts" So that means YOU want others THOUGHTS. You got em. just because it is something you dont want to hear, you dont have to be childish about it and throw a temper tantrum
