1978 - 1996 Big Bronco
Screwed IAC
Old Jun 17, 2003 | 10:39 AM
Pazuzu911's Avatar
Pazuzu911
Post Screwed IAC
Thanks to a couple of rusted screws and a very handy Dremel, I'm in need for new screws for my freshly cleaned idle air control valve. Looking through the Haynes manual didn't give me any sizes and visually matching them at the hardware store didn't work either.
Rather than a process of elimination and killing the threads, does anyone know the right screw size?
Old Jun 17, 2003 | 10:46 AM
Pazuzu911's Avatar
Pazuzu911
Screwed IAC
Woops... 1990 Bronco, 302
Old Jun 18, 2003 | 11:34 PM
steve83's Avatar
steve83
Screwed IAC
It's metric, which is why you didn't find it at a hardware store. Visit your local U-Pull-It junkyard.
Old Jun 19, 2003 | 06:35 PM
bigric's Avatar
bigric
Screwed IAC
I'd just take the throttle body to your local parts house and match them up; it's a snap to remove. I'll try to pull one of mine tonight and check it for you.
Old Jun 19, 2003 | 09:31 PM
Pazuzu911's Avatar
Pazuzu911
Screwed IAC
Thanks for the info guys
Had a feeling it might be metric. Standard would be too easy of a fix
bigric: If you could do that I'd be eternally grateful!
Old Jun 20, 2003 | 09:06 PM
bigric's Avatar
bigric
Screwed IAC
OK, it's a 6mm bolt, the threaded portion is 0.8" long, so it's right at 1" overall, and it's got pretty fine threading on it. I don't have the exact numbers on the threads, so get a few fine-threaded ones and gently try them. Sorry for the hodgepodge of metric and standard units...
Old Jun 20, 2003 | 10:45 PM
steve83's Avatar
steve83
Screwed IAC
6mm x 1.0mm x 12mm
diam x pitch x length
Old Jun 22, 2003 | 01:29 PM
Pazuzu911's Avatar
Pazuzu911
Screwed IAC
Thanks for taking care of this headache for me steve & big!
