Easy Grill Question...
Old Sep 10, 2013 | 09:26 AM
zak8tac's Avatar
zak8tac
I just saved a 69 F250 bump from the crusher. The thing is a great survivor (99% rust free) however it was involved in a driver side impact. I found a new hood but also need a new grill and fender. Are the grills from the bump era all the same? I am well versed in the dentside specifics, but not so much for the bumps, any help would be greatly appreciated.
Old Sep 10, 2013 | 10:14 AM
Gembone's Avatar
Gembone
69 is a year specific grill. check out LINKY for the basic identifying parts from the bump years.
Old Sep 10, 2013 | 10:44 AM
zak8tac's Avatar
zak8tac
Well ****... thanks for the sticky, now will the other bump years bolt right up or are the mounting locations different? I think the odds of me finding a 69 fender and grill are pretty slim. I was able to find a hood off a 68 i think, so i got lucky there in the fact it doesn't have the fancy chrome trim.
Old Sep 10, 2013 | 11:45 AM
JEFFFAFA's Avatar
JEFFFAFA
The fenders are all the same on Bumps. As far as the grilles go They will all bolt up with a few minor differences. The metal panel behind the bumper (Ford called it a stone deflector) has to match the year grille you pick because of the recess for the 70 and up parklamps. The upper metal panel that has the hole in it for the hood latch striker has to match whichever hood latch you use.
Old Sep 10, 2013 | 11:49 AM
zak8tac's Avatar
zak8tac
Many thanks to you gents!
Old Sep 10, 2013 | 02:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Gembone
69 is a year specific grille.
This only applies to Rangers.
1967 painted steel (C7TZ-8200-B) and anodized aluminum (C7TZ-8200-C) grilles are 1967 only. 1968/69 painted steel grille (C8TZ-8200-D) is the same.
1968 anodized aluminum grille (C8TZ-8200-E) is the same Custom Cab/Ranger and 1969 Custom Cab only.
1969 Ranger anodized aluminum grille (C9TZ-8200-A) is 1969 Ranger only, center horizontal grille bar inset painted red.
Painted steel headlamp bezels same 1967/69. Anodized aluminum headlamp bezels same 1967/68 and 1969 Custom Cab only.
1969 Ranger anodized aluminum headlamp bezels are unique as the area surrounding the seal beam is painted black.
Jeff: FoMoCo replaced the 1967/69 stone deflector (C7TZ-17A862-A) with the 1970/72 type (D0TZ-17A862-A) for use as a service part replacement.
Old Sep 10, 2013 | 04:58 PM
MIKES 68 F100's Avatar
MIKES 68 F100
other years will fit , just won't be 69 correct .
Old Sep 11, 2013 | 09:05 AM
Salter70's Avatar
Salter70
So if I wanted to put a 67 grill on my 70, what all would I have to change?
Old Sep 11, 2013 | 12:36 PM
JEFFFAFA's Avatar
JEFFFAFA
As long as you change the whole assembly you will be fine. Including park lamps and headlamp bezels.
Old Sep 11, 2013 | 01:37 PM
Salter70's Avatar
Salter70
Thank Jeff. I bought a whole parts truck so that shouldn't be an issue.
Old Sep 11, 2013 | 02:07 PM
JEFFFAFA's Avatar
JEFFFAFA
Your welcome. Nose around this forum. There has been many pics of trucks with 67 grilles. Painted white, Painted body color, and polished. You can get a idea of what you want to do with yours.
Uni Moe
15
May 22, 2015 08:28 AM
pwrplay
Mar 14, 2013 06:37 AM
798hand
35
Jun 2, 2011 12:06 PM
rmalottwtes30
Feb 24, 2008 01:13 AM
AirSmitty
Jan 18, 2004 06:50 PM
