frontend/grill
Old Feb 23, 2008 | 11:12 PM
rmalottwtes30's Avatar
rmalottwtes30
frontend/grill
will the grill on a 87-89 work on a 85? Im talking about the fenders as well.
Old Feb 24, 2008 | 01:13 AM
chad85's Avatar
chad85
Well you would have to use the whole front clip like hood, grille, fenders,radiator support, and probably other little things. The cabs are pretty much the same so it is a bolt on set up. I have seen it done before. If that is the front end style you like, up to a '91 will work. If you wanted, the 92-96 style front clip will also bolt right on.
