anyone know how to take out the dash where the radio is in.. i no there all clips but there radio is like stuck on there and i cant see any screws or bolts..???? help
If it is the stock radio, you need to buy these tools form an auto parts store that are specially made for the factory radio. They look like u-bolts and will fit in the holes on each side. Push them in and it releases clips so you can pull it out.
I just used some wire formed in a u shape to get the old radio out. Then I got my new one from crutchfield, and the tools were in there to remove the old one.
A couple pieces of coat hanger will work to push in there and release the latches. It doesn't work quite as well as the tool that is made for the job, but it works none the less.
The tools are sorta spear'd at the ends to help them go in.
And they have a little notch so they grip the radio better and allow you to pull it out of the dash with the tools, but I have found it almost as easy to use 2 pieces of coat hanger and just keep pressure on the radio (pushing the coat hanger tools outward sort of "pinches" the radio in between them) and pulling it out that way. It will certainly work in a "pinch" (pun intended).
