transmission please help
Old Sep 9, 2013 | 04:49 AM
birdman91's Avatar
birdman91
I have a 96 f150 5.0 4wd short bed with a automatic e40d transmission. My transmission went out on me and I'm have a hard time finding one for a 96. Would I be able to pull a tranny form a 90-96 bronco and put it in?
Old Sep 9, 2013 | 08:17 AM
baddad457's Avatar
baddad457
You're better off in the long run just getting your's rebuilt. With another used one, you have no idea how long it'll last, or if it even works to start with.
Old Sep 9, 2013 | 09:43 AM
Conanski's Avatar
Conanski
Before you go spend hard earned money and time on replacing the trans have you positively determined that the trans is actually the problem? Sensor issues are the #1 cause of issues with this thing so you need to exercise due diligence before spending a dollar on a rebuild or you could be completely wasting your time and money and still have the same problem.
Old Sep 9, 2013 | 10:21 AM
baddad457's Avatar
baddad457
The Speedo cluster going south can have a huge effect on how the transmission acts too. Had this happen to a 95 van I had with an E4OD. Replaced the cluster and it was fine afterwards. Too many tire size changes will kill the cluster, it's only programmed to compensate for 5 tire size changes total, anything more will screw it up and the transmission goes haywire as a result.
Old Sep 9, 2013 | 01:30 PM
birdman91's Avatar
birdman91
I was able to drive it for a little while but I had to start out in low and work my way up to drive. If I tried to take off in drive all it would do is rev and then kick real hard. Now I can't even do that all I have is reverse.
Old Sep 9, 2013 | 02:03 PM
85e150's Avatar
85e150
E4OD?
Ford Transmission Spotter's Guide .: Articles
https://www.ford-trucks.com/user_gal...id=169485&.jpg=
Old Sep 9, 2013 | 02:08 PM
baddad457's Avatar
baddad457
That's what mine did when the speedo cluster went out.
Old Sep 9, 2013 | 05:56 PM
Conanski's Avatar
Conanski
Yeah there's probably nothing wrong with your trans, pull the codes before you do anything else.
Old Sep 9, 2013 | 07:25 PM
birdman91's Avatar
birdman91
How much and how hard of a fix is a speedo cluster?
Old Sep 9, 2013 | 10:03 PM
baddad457's Avatar
baddad457
Do a search on ebay, you'll pay a LOT less than I did at the dealer 10 years ago. They hit me up for around $550 if I recall, I looked at the clusters on ebay recently and they were nowhere near that expensive. I may just buy one to keep as a backup for mine. The newer vans went back to the mechanical speedo's probably just for that reason. I looked at quite a few 98-2000's and they all had the older mech speedo cluster
brian_06328
Aug 31, 2014 12:38 PM
Fordman_Evs
18
Jun 10, 2010 10:08 AM
fkaster01
Apr 2, 2009 06:27 PM
chruby99
Jan 12, 2009 10:11 AM
droppedf100
Nov 7, 2007 06:57 PM
