Issue with 2000 Ford Excursion Pats
Old Sep 7, 2013 | 09:34 PM
kylehoff123's Avatar
kylehoff123
Hello,
Ok about three weeks ago driving from Austin, my truck would not shift come to find out it was a fuse that blew. Well I pull over and replace the fuse it starts right up I get about a mile from my house and it blows again so I shut off my x and then replaced the fuse. Will not start
Now I am getting a Pats code 1:6 and my obd2 reader says no link on my x. It used to read it all the time. I am trying to figure out what I can check to fix this problem are there any relays. Oh also my check engine light does not come on when I turn the key but my truck does crank. does this mean there is no power to my ECU. I did replace my ecu and it did not solve the issue. Thanks for all the help.
Old Sep 7, 2013 | 11:20 PM
mtnsammy's Avatar
mtnsammy
Not sure what the code is but I remember reading the fuel bowl heater would blow fuse #6 I think and the common repair was to disconnect the heater. Get a better scan on codes or trace what items are on the fuse circuit. I bet it is a common issue like air heater or fuel heater.
Old Sep 8, 2013 | 12:52 AM
Stewart_H's Avatar
Stewart_H
That really depends on which engine he has. It definitely sounds like the fuse for the fuel bowl heater though.
Stewart
Old Sep 8, 2013 | 01:05 AM
kylehoff123
I have a V10. Code 1:6 is the pats and Ecu are no communicating. Where is the fuse for the fuel bowl? Thanks
Old Sep 8, 2013 | 01:09 AM
Stewart_H's Avatar
Stewart_H
You don't have a fuel bowl. It's a problem that occasionally afflicts the 7.3L PSD.
Stewart
Old Sep 8, 2013 | 01:11 AM
kylehoff123
I thought that was a diesel issue! Thanks for the help tho
Old Sep 9, 2013 | 06:00 AM
kylehoff123
Can anyone help me ??
Old Sep 9, 2013 | 11:27 AM
Stewart_H's Avatar
Stewart_H
So your code reader is powering up, correct? It's just not reading the PCM?
Stewart
Old Sep 12, 2013 | 09:06 PM
kylehoff123
Stewart
Yes, that is correct. I have also noted when I Turn the Key I am not getting the check engine light on at all. Sorry for wait had a busy week
Tow Zone
Nov 1, 2013 05:24 AM
angel29
Feb 19, 2012 04:00 PM
Oslo
Jul 14, 2011 07:40 PM
benthere
Dec 15, 2010 09:37 AM
andrewc53
Nov 7, 2010 03:59 PM
