Georgia Chapter Join Chapter, Leader: OPEN SPONSORED BY:
Help! Starter issues
Old Sep 7, 2013 | 04:53 PM
Roswell's Avatar
Roswell
1990 bronco
Went to start it Thursday, put the key in the ignition and engaged starter.....engine did not start but starter stayed engaged and going....even after turning off the ignition and taking keys out. Starter kept going until it died.
Put on a new starter. When I went to hook up the battery the second I put on the second battery connector the starter engaged. No keys in the ignition.
So there must be a short somewhere......or could it be the solenoid?
Thoughts?
Old Sep 7, 2013 | 07:37 PM
Southern Bronco's Avatar
Southern Bronco
Starter relay(solenoid) is bad.
Old Sep 8, 2013 | 10:23 AM
Roswell's Avatar
Roswell
THANKS!!!! replaced solenoid this morning - problem solved.
Old Sep 8, 2013 | 12:30 PM
Southern Bronco
You are very welcome.
Old Feb 9, 2016 | 11:40 AM
Texican1911's Avatar
Texican1911
How long did that last? Same thing just happened on my son's truck. Replaced the relay, next morning the starter seized. Replaced the starter, 12 hours later the battery has to be disconnected to stop it from spinning. Replace the relay again, 3rd start and it's doing it again.
Old Feb 9, 2016 | 12:05 PM
ChiefM's Avatar
ChiefM
I would say you have a faulty relay, Just because it's new does not mean it's good. Cheaper ones are known to fail almost immediately, but check your wiring first.
Old Feb 9, 2016 | 01:09 PM
Texican1911
Our longest time mechanic (I work at a Ford dealership) just said the Chinese ones generally can't handle the voltage and to get the Ford one. So that's what we shall do.
Old Feb 9, 2016 | 01:31 PM
ChiefM's Avatar
ChiefM
I have seen it many times in the 73-79 forum. Since I have a 79 I have been trying to keep up on troubleshooting in case I run into any problems down the road .
Old Feb 10, 2016 | 08:08 AM
axelgawn's Avatar
axelgawn
Well, My 73 dent truck will stay running and I can pull the key out when its started.
jefflos
Jun 11, 2015 11:33 AM
shooter1710
Nov 25, 2010 04:55 AM
ridecolby
Aug 11, 2009 07:51 PM
Big Daddy J
1978 - 1996 Big Bronco
May 25, 2005 07:25 PM
whathappened
Bronco II
17
Sep 9, 2004 06:28 PM
