Is the frame bent or different size fenders?
I have looked at everything I can think of and can not find an answer. 49 F3 with a Jag XJS front end and a 5.0 efi engine. Tires are 17 x235 x80 on Amer Racing 3.5 off set Atlas rims and 5 bolt to 8 bolt spacers on front. I have measured both sides of the Jag to about 15 points on the frame for both sides and all measurements are the same. I measured the back of the cab to 4 points of the frame and only one was off by less than 1/4 inch. I measures the lower front fenders form center point to wheel well and they are the same. I measured everything I could and all came out the same on both sides. I even checked to be sure the tires were the same distance form the frame and 3 other points on the Jag rack and all were the same. But check out the drivers side compared to the passenger side. The rear of the well to the tire on the passenger is about 3 inches and the rear of the tire on the drivers is about 5+ inches!! What is the problem and how do I fix it
Would love too bring it to TS 13 ! but I would either have to have a number of spares or be ready to replace a fender. As far as pics from20 feet I will try tomorrow. I don't think the frame is bent as I had it all the way down to the frame and every measurement directly across or even x'd come out the same.I'm the second owner and pulled it out of the barn -- the farmer swore it was never in a wreck and the sheet metal was it reasonable shape with no signs of repairs. I just cant figure out what is wrong. Dave s
measured all of that -- top edge at hood to opening, headlight to opening, front of opening to back of opening door edge to opening. I even measured the total length of the opening edge and every one of them is the same on both fenders. It really has me baffled, I just hope someone has an idea of what might be wrong. The thing I am thinking is the drivers fender is sitting lower than the passenger side. Looking at the truck from the front it doesn't look like it is but I just don't know. I'm going back tothe garage now to measure the ground to the top of the opening and see what that is.
"Could the frame be in a slightly rhombus shape? Sounds like one side is 2" farther forward than the other side."
Joe
How would I check this -- if I measured from right rail to left rail then the same points on left rail to right rail-- in other words an X shape and the distance is the same wouldn't that say this is not the case because I did that and they are the same??
I think this may drive everyone crazy. dave s
Joe
Doing the cab measurement it seems straight on the frame -- I measured from the back of the cab to 2 points on the frame (bed not on truck) and only one wasoff by just a hair over 1/8 inch the other 3 were the same. I am saying the same to within an old mans eyes and a tape measure. dave s
Joe
Joe
So, just a stupid guess, are the two frame rail sides the same length?
