Is the frame bent or different size fenders?
Good suggestions but don't think its the answer--all measurements are same from front of frame to Jag front end, frame to wheel, all fender measurements. I bought it out of the last barn in Chicago it sat in the barn from 81 till 92 when I bought it- farmer's dad bought it originally got the big C and died, wife loved the truck and would not sell it until she became ill. Only had one other possible buyer but he wanted to drive it away to haul wood. They refused to sell it to him - when I came along and said I would restore to original look but upgraded drive train they sold it. Swore it was original and never wrecked so I don't think the fenders were replaced. Even showed me pics of hauling bulls to market in the back and said that and manure was why bed was shot. Original bill of sale said $1551.00 I paid $1500 and it had 51,000on od. so a buck a thousand miles!
Any other ideas??? I'm stumped. dave s
The pic is showing the fiberglass lower part I replaced the rusted out lowers with. Chicago winters take there toll. I did measure the cuts for the lowers and they are the same on both sides. The passenger side is on the side of the garage with out much room - will try for better pics asap. Again I do appreciate any ideas you all come up with- I am not just trying to shoot them down. dave s
Yes I put the Jag in and the 5.0 with a worldclass T5-- I originally was going to restore the Flathead 6 but it was really dead from being stored in the barn with water in rad/block. Finances and work put a stop to it for a number of years. We moved from Chicago to KY (semi retired)a few years ago and I started on it again. The frustrating part is everything I have tried to figure out what is out of whack has proven it is all straight. But something has to be wrong I just don't know what-- I am sure it is looking right at me and I'm too blind to see it. dave s
If they don't measure the same, start by checking the spindles and A frame for possible damage or twisting.
Are the tires the same size?
Sorry, couldn't help myself. It seems you have covered all the bases. I wonder if someone else looking at it could see something you have missed since you are so focused on it. Kind of like the rule of never proofreading your own writing.
Could you do a video walk around? That might shed some light on something off.
I was thinking the same thing. It is possible your suspension isn't square to the frame. Measure center of hub front to back on both sides. The truck might be right on, but then again your jag suspension could have had a previous wreck.
#29
The hood fits but a bigger gap on drivers side than passenger side. The wheel openings are the same. Pulling out of garage and will post pics -- If my thinking is correct and the cab mount and very front of fender attachment is messed up it would result in this problem. If I raise the cab a half inch or more and the front fender attachment would have to go up and therefore pivot the opening out some. I just have to figure out if they are messed up. dave s
#30
Cleaned the garage out enough to be able to pull the F3 out for pics. Side views were taken at same height and distance from truck. Front view shows the problem, I think. It looks like the drivers side is lower than the passenger side. How would I raise the front of the fender up - therefore moving the wheel hole up and out away from the tire.
